boost with edge comp
I am getting ready to install my edge comp box wire untapped...I don't have a boost gauge. I am going to lock the wastegate shut on my truck what is the most boost I can expect?
About 28psi with out the wire tapped... about 35 tapped...
I get the same (31-32) with the wastegate spring, as I did with the EZ. Wire is tapped.
Mike |
I was seeing 30 with comp untapped , before injectors.
with my comp and my injectors i can pull about 45 or so. i know i know its not good above like 32. im on a wating list for a htb2 :D
