boost
I just installed a boost gauge. I get about 25psi TST said I should see 30-35. I dont see any rips in the boots any other ideas?
You need a boost elbow or contoller in order to adjust the wastegate.i'd say your 25psi is right on the nose with that plate.If you had a leak you would see alot less I think
