Best way to bomb 1999
Old Dec 23, 2003 | 04:05 PM
Mopar_Mudder's Avatar
Have a friend that just got a 1999 3/4 ton 5 speed this past summer. He bought it used and it has about 240,000 miles on it.
First off we are going to do a 4" exhuast and Scotty Air on it along with some guages. From their I am wondering what the most cost effective way to add some power to it.
I basicaly have talked him into get the Edge EZ, told him the Edge Comp probably not a good idea from the problems I have heard with the injector pump. And a truck with that many miles I would think rasing the pump pressure would not be to good for the pump.
Is the EZ the best way to go, or is injectors or something else a better route?
Old Dec 23, 2003 | 04:06 PM
Re:Best way to bomb 1999
Sorry, should have been in the Performance section, little brain fart here :-[
Old Dec 23, 2003 | 04:22 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Done.
Old Dec 23, 2003 | 06:02 PM
DarrellB's Avatar
The respond very well to bigger injectors really improves the lowend power. 8)
He could pick up a set of used DD3's for a pretty good price and I wouldn't be afraid to pearce the pump wire either. 8)
DB
Old Dec 23, 2003 | 07:11 PM
dodgeram's Avatar
I'm running a comp and 275's right now on my 99 and I think that's about all the stock turbo will handle(38lbs boost), even with the scotty my egt's climb pretty fast
you could go the comp without the wire right now(ez mode) and a set of big injectors ........later when he becomes brave and gets the cash for a b1 kwikspool he can hook up the wire
Old Dec 24, 2003 | 02:59 PM
1BadDzl's Avatar
First thing he should do is GAUGES. EGT and fuel pressure being the most important. Boost is not a bad idea either. Bombing is a bug that only gets worse. Fuel box-injectors-turbo-exhaust-head work-bigger injectors-cam-twins-got the picture?
Old Dec 25, 2003 | 01:12 PM
DRD's Avatar
DRD
If you do hook up the wire on a box make sure you can afford a new injection pump. My pump failed on the first hard pull, only had 70,000 miles on the pump. It will either live or die, you'll know in the first 20 minutes or so.
mitch@jc'sCTD
Jan 1, 2006 08:19 AM
600 Megawatts
26
Jul 14, 2005 06:04 AM
flyfsh70
May 8, 2005 10:33 PM
YinYaker
Nov 10, 2003 12:28 PM
