BD XXX 155hp sticks.WOW!!! questions???
I just installed new injectors and HOLY!!!
Tons of power and my EGTs are only getting up to 1280* max with Boost @ 32#. from what i have read this seems to be OK. Not alot more down low but on the HWY lookout! Am i looking to blow that stock turbo or can I get away with it for awhile? getting tranny upgraded on Mon. i am no mechanic so does the Cummins have a rear engine seal that you can only get at by pulling the tranny? just wondering cuz after testing the new sticks out i noticed a new oil leak coming from front of tranny rear of engine? what kind of HP numbers with setup?
thanks Clay
Tons of power and my EGTs are only getting up to 1280* max with Boost @ 32#. from what i have read this seems to be OK. Not alot more down low but on the HWY lookout! Am i looking to blow that stock turbo or can I get away with it for awhile? getting tranny upgraded on Mon. i am no mechanic so does the Cummins have a rear engine seal that you can only get at by pulling the tranny? just wondering cuz after testing the new sticks out i noticed a new oil leak coming from front of tranny rear of engine? what kind of HP numbers with setup?thanks Clay
did you sell the 275's? Without a timing adavance somwhere like a comp or ez that is going to be a really smoky truck for normal driving clay, yes the rear engine seal can be replaced with the tranny out it is a one peice seal. And lastly it is the leaking oil of the engine oil type or tranny that will give us an idea of what it could be (smell it), but it is probably a rear seal but doesn't have anything to do with the injectors just dumb kuck.Your hy35 is going to struggle keeping up to those sticks beter start saving
J
J
for the tranny iam going with BD TC and VB. its engine oil for sure that's leaking. dumb luck for sure. only started doing it after the first WO run.
-would the Power Puck advance the timing enough? it was pretty dark out last night by the time i got them in. only saw a huge cloud when layin into the go pedal.
-hey "Greenworks" your old man want a brand new set of RV275s? I put those in and after 500km I called Albert @ Mckwynnes and got the 155's. Its been awhile since i was in your rig so it was quite the surprise when i hit the go pedal to the floor. the first run i thought the tranny fell off and turbo blew off.
going to get new ones anyways. turbo made quite a bit of noise when i let off the thottle.
Clay
going to get new ones anyways. turbo made quite a bit of noise when i let off the thottle.Clay
CTD Neil -the power puck is just one setting no way to turn off and i haven't removed the box to test out the smoke yet but driving around town no smoke unless i get on it. will pull box off this aft. & check it out.
Clay
Clay
Shawn.L.Turbo
Jul 16, 2007 06:21 PM
BigBlue
48
Jan 6, 2007 12:24 PM
Sea01Cummer
Oct 30, 2005 03:48 PM
greenworks
Jan 25, 2004 10:44 AM
