BD Stealth Plate
Has anyone used the BD Stealth Plate yet? For those who don't know, it replaces the cover on your VP44 and has a bolt with a leadwire to make contact with the pump. Designed so you don't have to pierce the injection pump wire if you're running a box that has that option, which will save your warranty too...at least that's the way I understand it.
I'm looking at getting one to go along with my new TST PM Comp. |
I used the blue chip cover (same exact thing) and I really liked it. It won't help your warranty though cause the dealer knows to look under the cover for the hole. It makes a very good connection and it doesn't mangle up the wire. It does make for removing the box a lot easier should you take it into the dealer.
So you have to drill a hole in the pump housing or something....under the cover?
If you look at the BD site, and click on the pic of the cover it looks like it just bolts onto the pump and there's a stud coming off the front of the cover. I don't see why they would market this as something that would keep your warranty if you could take it off and be undetected. http://www.bd-power.com/ram/product....20Cover&tt=ram |
No way to go undetected, the dealer can plug into your ECM and tell exactly what you have been up to, if they choose to do so.
If you play, be prepared to pay! |
So one difference between the Edge Comp and the TST Comp is that you have to "plug" the TST in. Whereas the Edge if you don't it acts like an EZ?
You got it.
