BD pressure Lock
Old May 7, 2007 | 12:06 PM
74dart's Avatar
BD pressure Lock
Is anybody running this in their tranny and if so what do you think. Does it work good and can you tell a difference.
Old May 7, 2007 | 01:46 PM
Gotlift01's Avatar
Most everybody I've talked to that has one or had one hasn't been impressed with it. I'm not sure exactly why they didn't like it, but it sounds like it just doesn't work all that great for the money. I'd spend the money on a valvebody instead, that'll make more of a difference I think.
~Nick
Old May 7, 2007 | 11:27 PM
WildBill's Avatar
They work excellent at what they were originally designed for, which is exhaust brake use. When the torque converter locks up, it increases line pressure by overriding the throttle valve cable. When you let off the throttle the pressure normally drops to idle pressure, with the pressureloc it keeps it up high to help the converter hold for engine braking. Also on trucks with more power (hence less throttle needed) it increases pressure to help hold under power while locked up.
Old May 8, 2007 | 04:10 PM
Mike Holmen's Avatar
The Guru
Mine would stick all the time. I had to take it apart lots of times. I have one in my garage, if you pay for shipping you can have it. Its just a bandaid to help keep pressure on your clutchs. A modifed valve body would also help. You can feel it on your throttle pedal as it would move your throttle position abit.
Old May 8, 2007 | 04:11 PM
74dart's Avatar
I've already got a modified valve body already just looking for something else to help.
Old May 8, 2007 | 04:18 PM
99globalwarmer's Avatar
i would save your money had one a while back wasnt worth the wait always stuck always had to clean. they really dont seem to me to be worth what they do, i woould get a new converter, a goerend or get a high performance trans rebuild kit.
JKM
Sep 23, 2007 11:38 AM
xp8103
Jun 2, 2006 07:00 AM
mr T
21
Jun 1, 2005 08:48 AM
Nuttymopar
Sep 2, 2004 07:39 AM
damon_achey
Jun 7, 2004 03:33 PM
