Backup Lights...
Backup Lights...
I got one for you guys out there...
Most of us have been mounting our backup lights on the rear bumpers. Well I finally found out why NOT to mount them on the bumper. Of all the rocks in a yard this one found the driver side light under the bump and broke the glass...
Here is a picture of before the mod...
Take notice to where the lights are hanging off the rear bumper... Good but not good enough...
Here some pics after the mod...
Backup Lights ON!
Showing placement...
Matter of fact they light up just as good as with them on the bumber! They are guarded by the sway bar and the axle tube so I really got to run some thing over to break these!
Backup Lights ON!
My only question is how well are they going to stand up to the pounding that the axle is going to give them? On the body there is some 'shock absorbing done through the tires, springs, etc.
Tom
Tom
The bulbs are mounted in rubber housings...
I've got a second set of bulbs sittng here... Also The bulbs will not be on while going foreward so the filament should last awhile...
No worse that mounting them to a old farm tractor or a backhoe I guess...
We'll just have to see how long the bulbs last...
Comparing the way you have them mounted to having them mounted on a farm tractor or backhoe is neither here nor there because neither of those vehicles will be traversing paved roads (complete with potholes and such) at 65mph.
Originally posted by NOSPIN4ME
I like them where they are mounted. You'll have to keep us posted as to how they hold up.
Well just have to wait and see...
The two lights cost me a whole $24.00 bucks... Like it hurts my feelings...
I sure won't want to mount of KC's or PIAA under there!
From what I've read, incandescent bulb filaments are more susceptible to vibration when the lamp is turned off than when it's on. The reason being the filament is less flexible when cold (turned off) and more so when it's hot, hence the greater likelyhood of breaking a filiment when the light is not on. Just the same, it will be interesting to hear how your fare in their new location.
Steve
Steve
I use to mount little WHITE fog lights to the frame in the back. Being fog lights, they would give off a nice wide angle and white would shine better then the typical yellow color. I would then sit in the driver's seat and have my brother adjust them when I looked in the mirrors. They lasted for 3 years without a problem and would shine about 3 - 10 feet behind the tires. It was great for plowing besides backing up. And being tucked way up on the frame, nothing ever got to them while driving.
I think you will find out very quickly that up on the frame would be much better
ill give you about 2-3 weeks between the pounding they are going to get and the dirt from wet roads if they do survive plus no fun getting down there to clean them
good luck time will tell
I'm trying to find a spot to mount them that will protect them from debris. I tried the frame idea and the beam path is very short. (Can't see any thing out the mirror. The tow bar block a good part of it.
If I move back the springs are in the way. But the beam path is better. I though about building a bracket to drop them but now they un-protected again... Rock, logs, etc...
So I figured I would try the axle... So far they light up great at night! The beam is over 100 FEET! Behind me.
The light buckets are rubber... The are fairly soft as well... So it might protect from blow out the bulbs.
As for washing... Not a problem... I washing the engine are the underside of the truck every weekend. I do have some serious water pressure here 180 PSI from a hose tap. Irragation system from a dam 1/4 mile up the mountain! Now hook that up to a high pressure washer! LOL! I can clean the underside of my truck without laying on the ground!
As for the people that think I'm nutz... Well you never find out if you can design something new unless you try some weird ideas...
So far I've got 200 miles on them with rough dirt roads and both light up yet!
Tom
Tom
I'll keep you guys updated!
