-   Performance and Accessories 2nd gen only (https://www.dieseltruckresource.com/forums/performance-accessories-2nd-gen-only-91/)
-   -   ARP Head Studs (https://www.dieseltruckresource.com/forums/performance-accessories-2nd-gen-only-91/arp-head-studs-64392/)
BARTMAN Mar 23, 2005 01:36 PM
ARP Head Studs
All,
Just want to confirm that ARP 247-4202 is the correct part number for a 24V 5.9. Also, let me confirm installation procedures;
1. Remove head bolt, one at a time, in the correct torqueing sequence, and install the new head stud.
2. Put anti-seeze compound on head stud, and tighten until it bottoms out. Then, back off stud 1/8 turn.
3. Torque head nut until reaching 96ft/lbs.
4. Continue until all studs are installed.
5. In proper head nut torqueing sequence, torque nuts in increments until 115-120 ft/lbs is achieved.
Is this correct?
Thanks for your time.
BARTMAN
Jambbii Mar 23, 2005 03:39 PM
Pt number is good and all the steps look good to me.
Have fun
MY WORLD Mar 24, 2005 04:38 PM
ARP Head Studs
Jambbii,
Is that the same for a 12v ?:D
What is with the 1/4 extra turn stuff???? [eyecrazy]
Thanks,
Wayne
Jambbii Mar 24, 2005 04:59 PM
Yeah same routine, do you mean the 1/8 turn? Well if that is what you are refering to then he means backing the stud 1/8 turn from bottoming out. I guess if you bottom the stud out (screw it all the way in) then as the engine heats up then everything can expand and push the studs up just a tad . I made the mistake of bottoming the studs out the first head gasket and I thinks thats why it blew.
