Air Lift Air Springs ??
HI
anyone using the air lift brand air springs ?
my truck came with them but the lines were cut so i may need some new lines / fitings ?
also this truck has air shocks tied in with the air spring lines ,and lines ran toward the front as if maby it had air shocks up front also ?
shocks are white with small red lines . ranchero maby ??
found an air port along frame driver side but cant test till lines get repaired !
anyone familiar with this setup ?
where do i get fitting and lines ?
thank you !
thank you !
techsupport@airliftcompany.com
http://www.airliftcompany.com/downloads.html
You could email that address with your questions or see if you can look it up via the link above on their online manuals
Jordan5687
Jan 29, 2015 10:32 AM
53 willys
23
May 19, 2008 06:14 PM
rodsram
13
Dec 12, 2007 08:48 PM
95turbo4wd
Dec 12, 2007 05:59 PM
