air dog install. other parts needed?
Old Mar 19, 2009 | 07:34 AM
My truck can't keep fuel pressure up now I have put a edge juice w/ attitude on it. If I ordered up the 150 gallon Air Dog pump w/ filters, on sale now, what else would I need to finish the install. Would I bypass the stock water filter and fuel filter. Do I need new fuel line? what size? Do I need to order a "draw straw" to get the fuel out of the tank? Anything else I should know before ordering parts / pulling the truck in the garage?
Old Mar 19, 2009 | 07:54 AM
nickg's Avatar
The Airdog comes with EVERYTHING, to install it, its a complete kit, do some reading on 1/4 tank issues, tou MUST install the drawstraw properly.
Heres a link, with the issues I had, others posted some good ideas. depending on your fuel module, I'd instal BOTH intake and return in the fuel module. If you opt to drill the fuel tank, make sure you cut a shallow angle or notches in the drawstraw.
http://www.cumminsforum.com/forum/98...vs-carter.html
Old Mar 19, 2009 | 08:43 PM
badme's Avatar
I just bought the same pump for my truck. I also bought a vulcan draw straw I and a tapped 90 degree fitting part # POET8. I bought the fitting to hook my edge juice pressure sender to it and the draw straw so the return fuel will dump into the fuel sender rather than the filler tube. I did not want to suck the sender dry. I bought these direct from vulcan online.
nbaggett89
Dec 26, 2015 09:36 AM
trailinone
16
Jun 19, 2009 04:28 PM
herb
Jul 18, 2008 08:25 AM
CTD_Neil
Jul 19, 2005 08:13 PM
Hoss
Jan 7, 2005 08:28 PM
