Adrenaline Beta Testers - Phase 3
#46
I'm all for messing with it obviously, I just did not know if you were trying to make something particular happen?
Is this version easier to use as far as the interface is concerned?
#47
As far as interface, I'd say it's ten times easier. The biggest plus is seeing what tune you're on when you're looking at the gauges. Aside from that, it's nice having "save tune" in the same menu as the parameters. Little changes make big differences, for sure.
#48
Quad, I've been waiting to load the new stuff until after the sled pull on Tuesday, because I know this comp tune is absolutely perfect on my truck & I don't want to mess things up. If I were to update it now, is there a way to load the comp tune in the Pulse the way it is? Then I can make other custom tunes from that point?
#49
You can load whatever tune you want into the Adrenaline and the Pulse will work with it even with ver 1.3.2
You can ONLY custom tune the special file I sent you with your serial number.
So if you wanted to update it, play with it and then before the pull go back to the COMP tune then you can do that easily.
#51
#52
From here on out, all you have to do is just load whatever tune into the adrenaline that you want. The only one that will have custom tuning is the ADR tune that was sent named as your serial number.
If you load a tune that doesn't have custom tuning enabled you'll be able to click "custom tuning" but it will take you nowheres.
#53
#54
Quad, I have my Pulse Updated. I just havent recieved the email with my serial number adjustable tune. Can you or justin contact me please?
jfoster@yaleflorida.com
Thanks,
Josh
Thanks,
Josh
#55
Just an idea, which I know some would like and some would despise. The ability to "rename" tunes, so that instead of Tune1 or Tune2 maybe you'd have "Default" "Towing" and "Strip", or something.
#56
Anyone else lost IAT readout with the new Pulse Software? I can't get it to work anymore!
Also having trouble locking in the Tire Correction Speed readout. Both worked well with v1.2.8??
RJ
RJ
#60
So, will I have to download the Pulse again before switching back to comp tune? Meaning if I were to load the new update into the pulse now, will I need to go back to the old file [Pulse] to use the comp tune or will it still work, just won't be able to adjust timing/fueling etc. With the comp loaded.
