adr custom tune save question
Hey guys I was just wanting to know can you save the dyno, comp and adr 1000 tune's all on your pulse?
I know you can download what ever tune you want and change it and save it to tune 1 or 2 but can you just load the dyno tune to the module save it to tune 2 then load the comp tune save it to tune 1 and then load the 1000 tune for a default? thanks |
anybody know?:confused:
Yes you can but, the only thing different between the new tunes is the max pump strech (wire tap fueling maximum). Now that custom tuneing is enabled, you can just change that setting from the base 1000 tune and save it in tune 1 and 2....This will save lots of flashing on the ADR.
I originally did this but now just leave it on the more agressive tune. I did bump my can min to 35 and wire tap min to 40. This gives near stock driveablity (little to no smoke,surge,ect) until I hit 40% throttle...then the fun begins :) |
