99 24v cummins
99 24v cummins
I have a 99 with the 24v Cummins that is pure stock I would like to know what would be the best route to take as far as performance torque and horsepower without rebuilding the tranny right now. any suggestions would be appreciated
Well, most everyone here will highly suggest gauges for a start. Fuel Pressure, Boost and EGT are good to get for a 98.5 - 2002 truck.
For performance, easy and cheap would be to pick up a used Edge EZ box. That advances injection timing a bit as well as increasing fueling a small amount. Also ditch the stock muffler--it's a restrictive design, and replacing it with almost any straight through type muffler will be a noticeable improvement.
That combination should get you maybe 30 HP and some mileage gains. You can't really bump up the power too much with the stock transmission (I'm assuming you've got an automatic) unfortunately. That said, don't underestimate the benefits of a good tranny rebuild. A good torque converter and valve body will make it drive like a whole new truck.
Mike
Mike
The Smarty is a great little programmer--it'll give you the same benefits of the older Edge EZ, but without the extra hardware. However, it also gives you a lot of other things as well such as pulling codes and speedometer correction when using non-stock tire sizes.
It's just a very cool, very high quality piece of gear.
My signature is up to date w/mods. I did a ton of reading on here and added mods mostly to get me better fuel mpg. At the same time Hp increased. Overall I'm pretty happy w/the truck.
Sell yours while it still works good and install one of these -
http://www.xtremediesel.com/XtremeDi...cTransmis.aspx
The same way I feel about skyjunker, at most "so-so" product. Find an Edge Juice or Quadzilla Adrenaline, these will have gauges and you won't really have to upgrade down the road. If not, then a smarty + gauges (fuel psi, tranny temp, egt).
I agree with High Bid on the Superchip programmer.
The tranny temp gauge is a great idea, especially if you end up with some mild performance upgrades and still run the stock tranny. You can potentially get some really high (damaging) fluid temps pretty easily, especially if you give it lots of throttle in overdrive when the torque converter is unlocked. In OD with the torque converter locked up, you can also easily run into an expensive problem because the stock torque converter clutch can't hold much power. To be fair, it wasn't really designed to.
When I installed the tranny temp gauge in my '92, it was a real eye opener. I saw very quickly that some of my driving habits really made the tranny fluid temps shoot up quickly. So for me it was a huge value just having it for day to day driving.
Mike
Mike
king5335
26
01-17-2010 07:57 PM
buddy26
16
01-14-2009 07:29 PM
cartuning.at
02-18-2005 03:55 PM
02Texas_Rattle
12-05-2003 05:08 AM
