-   Performance and Accessories 2nd gen only (https://www.dieseltruckresource.com/forums/performance-accessories-2nd-gen-only-91/)
-   -   98 24valve high rpm miss (https://www.dieseltruckresource.com/forums/performance-accessories-2nd-gen-only-91/98-24valve-high-rpm-miss-214591/)
landscaper3 Aug 19, 2008 01:43 PM
Hello, I have a 98 24 valve with 100+ Edge nozzles, Edge/attitude, Holley Blue pump new lift pump and AEM filter, this year I have had a problem at top end it misses reallllly bad 3/4 and below are fine but up high is terrible until it shifts. I do need a desperate transmission change but I would like to take care of this issue first. ANY HELP?????
98.5Hotrod Aug 19, 2008 03:29 PM
Unhook the Edge, make sure you plug your map sensor back in and see if it still has a miss at high rpm. If not your edge box may have a problem. Also are you running a fuel pressure gauge if so what is your fuel pressure at wot.
landscaper3 Aug 20, 2008 08:26 AM
Fuel pressur w/o is around 10psi, the map sensor is the one the edge hooks to correct? I will try that and see.... runs strong down low but seems to run out of fuel or like that up high on the rpm. I think it should shift quiker, i think it stays to close to the rpm limiter up high if there is one with the edge.. Also could it be de-fueling to much??? And if yes how to change.
Thank you for your response...
landscaper3 Aug 20, 2008 11:27 AM
The truck stays in gear wayyyy to long befor shifting to the next gear and stays on the rev limiter..
