4BT injectors
Yea I think these guy's a comparing apples to oranges.
The 4b with a VE pump and stock inj. lines.
The B eng. 370's won't work with those lines.
We run a basiclly stock injector with the pop pressure
jacked up.
The shop is in Newburgh, NY..
jacked up.
The 370's can be made to work, but you have to use the 1st gen injector bodies...
Yes, there is more to it than just custom injectors.. You can make some good Hp with the 370's/ POD... but the Big HP numbers are coming from custom injectors and/or EDM's... And you will need the pump to support the HP... You might have a 4 cylinder.. but there should be some bigger plungers/head/rotor setups out there...
Good looking Ranger...
4 bt injectors
Yes, when we first built the engine our old pump guy said the injectors
were 370's and in fact they're jacked up 300's.
Thats how we ran into the 4 hole problem.
We have an inline pump being done right now and a new set of 370's
should be good to go in the spring.
I'll keep ya posted, 6bta...
driverswanted
07-08-2004 10:22 PM
