4" exhaust ?
QUIETEST? I didn't want to listen to a drone and appretiate a quiet system, especially on long trips pulling a load. For that reason, I had Jardine put 2 mufflers in series. They said it wouldn't reduce performance any - just added $60. It is as quiet as the factory system, however the pitch seems a little lower. I love it. My only disappointment is that the EGTs didn't drop as much as I had expected.
Steve
Steve
I have the warpspeed 4in exhaust and love it. Very simple install (once you get rid of the stock system). I have mine straight piped and there is a slight to medium drone at highway speeds. If you plan on leaving the muffler on, then I don't think there will be a drone. Great price and great product.
Originally Posted by apwatson50
If the pressure is 1:1 accross the turbine than the only thing making the exhaust gasses go through the turbo is the pistons forcing it through.
Nature abhors a vacuum,as they say. You are correct that the pistons are forcing it through, but they do that precisely by eliminating a 1:1 ratio.
I would tend to agree with Rowland that backpressure is cumulative. IOW, the backpressure contributions of each element in the exhaust are separate entities. So the turbo's backpressure is a function of the turbo. The exhaust backpressure is a function of exhaust, etc. So you can't change the turbo's backpressure by changing exhaust-- you change the turbo to do that.
I think RJ is right to say that TIP will ALWAYS be more than TOP, simply because TIP is the SUM of TOP PLUS the resistance of the turbine. It's cumulative.
So, TIP *must always* be higher than TOP.
I'd also suggest that exhaust should be matched to turbo size. Because as the turbo gets bigger (and therefore offers less restriction), then the restriction of the pipe becomes a higher percentage of the overall restriction picture. It's a higeh disadvantage that exhaust pipe tubing is generally only available in increments of a half inch or full inch. The flow rate increase of 5" to 4" is considerable-- almost double.
I'll close by stating my belief that high EGT is MUCH more related to turbo sizing than exhaust size. I believe that an HX40 with a stock exhaust would lower EGT more than an HX35 can with a 4" exhaust.
jlh
Your TIP has more to do with your exhaust housing. now measure your TIP and your TOP(turbine outlet pressure) if those two are 1:1 or close than you need bigger exhaust.
Yes, but your FACTORY exhaust will keep TOP well below TIP even with a HUGE single charger.
For reference, the stock turbo is roughly equivalent in flow to a 3/4" pipe. Makes the stock 3.5" exhaust look downright huge.
If your boostP ratio is getting far above 1:1, I can ASSURE you, that it's not because your exhaust AFTER THE TURBO is too small.
I'd match exhaust pipe to turbo. Twins are best with 5"-- most big turbos need 5" outlet anyway.
4" will accomodate any single on the market with relatively insignificant backpressure due to exhaust pipe flow.
To put numbers on this: The rule of thumb (per David Vizard) is that exhaust will frrely flow about 115CFM/sq in of sectional area.
Thus, 4" will flow 1445 CFM. That's a LOT of air.
4" is fine even with a somewhat small set of twins, running a reducer from 5" outlet to 4"pipe. Doesn't cost much in the way of HP or cooling at all.
IMO, you'd have to be running some rather large twins (HT4C or bigger on bottom) to even approach NEEDING 5".
5" will freely flow 2258 CFM. That's plenty to supply an ISX at 600hp 14L displacement.
jmo
You can get a 5" system here for less than most places charge for a 4". MOTOBLUE™ MONSTER 5-INCH EXHAUST SYSTEM $349.00
http://www.rpmoutlet.com/dodgecdd5.htm
I also ordered the Stainless tip and man is it nice.
Dusty
Now you show me that after i already ordered. I sure never seen a 5" for that cheap. Dusty, wanna sell me yours for $125??
I know, I know I pussed out...
I think I can... I think...
I've been looking for this kind of info!!
jmo
jmo
roughstock
11-02-2013 01:48 PM
PEAKSTRYDE
10-11-2007 04:20 PM
VikingDiesel
47
05-11-2007 12:52 AM
Hemlockusa
01-28-2006 07:07 AM
