:)37/13.5/16's X-Terrains
Thought maybe these would fit on my 2nd gen. With the 4.5" Skyjacksr , but thought I'd look to the wise men out there.
Re: :)37/13.5/16's X-Terrains
What size do you have on there now?
Turn the front wheels to lock and see how much clearance you have between the wheels and the fender edges.
Might have to have someone hold them there while you measure.
Also see how much room till they hit the control arms.
Take the diamter of your current tires, add the above figures and if you come up with more than 37 inches then the answer would be no.
Also figure in the extra width you gain by going to a 13.5 inch wide tire.
315's are just about 35" tall and 11" wide, if that's your starting point
Stock size is about 30" tall and 9-10" wide. (265's)
My 2002 with the 4.5 skyjacker won't clear the 37's in front without longer control arms.
Rear is no problem.
phox
Rear is no problem.
phox
Hey, I can fit 37" Boggers on my Ram with only the 4.5" SJ. I had to hammer the corners of the fenders because the tire DO rub a little when flexing. You may have to do some cutting, but nothing that is too noticable. I plan on running another 3" of lift, eventually, and some 38s. Hope that helps
Crimedog
21
05-01-2005 05:08 PM
alltork
20
05-11-2004 07:35 PM
