35 inch tires with leveling kit
I tried running 315's on mine with just the 2inch leveling kit and couldn't even turn a mild corner without tearing my front mudflaps off.
I did have aftermarket rims with less backspacing than the stockers though.
Had to go to the 4.5" lift to get them to clear completely, and I can still rub them at full lock and stuff.
No rub at all on the control arms with less backspacing.
phox
phox
Thanks I am starting to think about running a 295/70R17
I am going to be hauling around my jeeps and dont want a big lifted truck to do it with but would like to fill the wheel wells a little better.
Thanks bob4x4 I would like a 35 but I dont want to lift it more than the 2inch spacer in the front and even that I am not sure about.
I want to be able to pull a gooseneck with 2 jeeps and somtimes a trackhoe or skidsteer and dont want the truck to tall or have the front end sticking up higher than the rear.
I have my jeeps to lift tall and run big tires.
Location: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
1 Post
I'm not running stock wheels, but the tires are 35 12.50 17's. And I'm only running a 2.5" coil spacer up front. No rubbing anywhere.
Here is my truck with 315/75 R16 Maxxis Buckshot Mudders. I love these tires. The rims have 4.5" backspacing if I remember correctly which is less than stock and keeps my tires from rubbing at all. I have skyjackers D25 2-2.5" overstock coil springs.
i have got a leveling kit with some 35" procomp xtreme terrains, the rub a little bit at full turn while hitting a big bump but nothing major, oh and stock wheels. no pics sry, camera is broken, i will see if i can get some for you though
Thanks for all of the pics guys it looks like I am going to be fine to run a 35.
Now I have to decide buy now or wait until the spring and finnish wearing out my tires.
are you looking for an all terrain type tire or a mud tire, like i said ealier i have those procomp extreme terrain a/t's and i love them they wear great, look good, very quite, and have pretty darn good traction on and offroad. i would rec. the extreme's or some goodyear wrangler's
