-   Performance and Accessories 2nd gen only (https://www.dieseltruckresource.com/forums/performance-accessories-2nd-gen-only-91/)
-   -   3000 gsk, do I got it (https://www.dieseltruckresource.com/forums/performance-accessories-2nd-gen-only-91/3000-gsk-do-i-got-70423/)
bigair Jun 14, 2005 08:17 AM
Was thinking of getting 3000 gsk for a while now but thought I should see what it had before I spent my hard earned money. Well I left it in first and to my surprise truck went all the way to 3200. It didnt run great at 3200 but it en fine at 3000. Do I already have springs or can this be done with stock equipment. thanks
TxDiesel007 Jun 14, 2005 08:25 AM
My truck does not have it
I can tell because when i run it hard it rather defuels at about 2400 rpms at fifth gear, yet it does fuel hard on all other gears to about 2800-3000 rpms, after that it just seems to bog down.. IF you have any of these syptoms, probably no GSK..
TX
bigair Jun 14, 2005 10:53 AM
I got an auto so I dont know about 4th I would be going way too fast by the time I got to 3000. Maybe I'll try it in second toay on the highway and see if I get the same results
gunracer1 Jun 14, 2005 10:53 AM
no you don't have it, my stock 215 pump would free rev to 3500. the gsk fuels much harder on the big end.
cumminsdriver635 Jun 14, 2005 11:31 AM
How many rpm's does it go to if you just mash it in gear? I doubt you have a GSK yet.
Eric
signature600 Jun 14, 2005 11:49 AM
put it in third gear, then hammer down...if it falls on its nose above 24-2500, you don't have them. It will slowly work it's way up to the redline if it doesn't have the springs.
If it wraps right up with a load on the engine, you have the springs.
Chris
bigair Jun 14, 2005 02:13 PM
thanks for the input I'll try it at lunch
