300 HP injectors in a stock 24 valve?
Can I put 300 HP injectors in a stock 24 Valve without throwing any codes? I am not concerned about the tranny.
May need to do something with boost. You will probably need a boost fooler.
No code that I can think of, but will throw lots of smoke....at the very least - a boost fooler!
Curiosity overwhelms .... Why would you want to do that? |
Found a good deal on some injectors, I will be doing an edge soon, and some other mods.
Where are you getting the 300 injectors from, Phil? Bosch made 300s and 370s for the 12 valve motor, but only 275hp injectors for the 24V motors (for the RV motors). It sounds like someone may be selling some snake oil....
John |
Bosch makes 300's there for fire truck applications.
Torquemech,
The guys on the TDR talked about those awhile back. They found that the P/Ns for the injectors were the same, but Cummins did make a 300hp ISB. Here's a link to the thread: http://www.turbodieselregister.com/f...=300+injectors John |
hey phil whats with 300s just go with the supermentals like john and get it over with i want you to keep up while following[laugh]
