2001 Dodge Ram3500 Duelly 24v
I Pull Heavy Equipment Trailers Looking For The Best Programmer/tuner For This Truck,i Would Like To Add Stacks,frsh Air Kit But Dont Know Which Won Is The Best And Since There Prity Pricy I Only Want To Buy Them Once Truck Has 125,000 On It.would Greatly Appreciate Any Help With This Thanks.
If you are going to keep the stock turbo you should go with a mild programmer like the edge EZ which is a 60 hp gain. This will keep your exhaust temps from getting too high from over-fueling a small turbo. www.edgeproducts.com
Post your location, there are probably members close to you that can give you a ride with different power adders. Don't forget that an EZ or similar box will improve your mpg as well (as long as you can keep your foot out of it). I borrowed an EZ about 8 years ago and that got me started... now I'm in so deep I'll never break even, but the grin is worth it.
depend'n on which programmer you want, YOU MUST GET GAUGES....some, like the Edge Comp w/ additude has gauges, or the quad adr.....but the rest (correct me if i'm wrong) don't have gauges.....
as far as stacks....build your own...if you look in the right places you can build your own for half what most of these companies want for them.....
Eye4Mud
Jun 10, 2008 11:42 AM
mavericks3500
Mar 5, 2004 02:47 PM
