#10 plate vs. #100 plate
What performance differences will there be with either a #10 plate vs. a #100 plate on my 12v manual 98 cummins?
#10 will keep your egts lower.
#100 may give you more hp but you might not be able to use them before egts go though the roof. #100 requires a lot more foot control than a #10, can be a PITA when towing. |
https://www.dieseltruckresource.com/...5&d=1244205658
theres a link to a picture of a good "template" if you want to call it that. you will be able to see that a 100 plate is very close to a 0 plate with the difference being that a 100 plate limits your low end fueling more. a 100 plate will give you more power like infidel said. but without some more supporting mods, like more air, your EGT's will be insane. a 10 plate is very controlable. and you can always grind a 10 plate to a 100 plate if you dont like the 10 but you cant go the other way. |
Originally Posted by infidel
(Post 2506199)
10 plate defuels on the top end, which I never liked. Thats whey I run 0/100 plates, stronger top end. AFC controls the bottom end, so 0/10/100 doesn't matter a whole lot in that respect. |
Hey, I was digging through some older threads and this one peaked my interest. Check my sig, I have a 1998 auto with a 3K GSK on it. But, it seems to just fizzle out in the upper RPM range. It does really well up to about 2000-2200 RPMs but then real power seems to vanish. Would a #100 plate make a difference in the upper RPM range?
Would a #100 plate make a difference in the upper RPM range? One source> http://www.pdrdiesel.com/products/40...it-583-35.html Install> http://pacbrake.com/PDF/L5658.PDF |
4K Kit
I have that exact kit. But, when the guy installed it he said that I should leave out the inner springs unless I got the 60 lb valve springs. I am not really interested in going that drastic.
If you put in a 100 plate, it will help out your top end, but it won't extend your rpm range. The 10 plate defuels the top, the 0/100 doesn't, so you will have more power up higher.
Originally Posted by efbeason
(Post 2584345)
I have that exact kit. But, when the guy installed it ...
Originally Posted by Fueling around
(Post 2584920)
Did he advance the timing? You need around 15° to help the 2,000+ rpm hp curve.
I just switched from the #10 plate to the #100 on my truck. I haven't pulled with it yet but, running up and down the mountains here, it actually runs a little cooler and pulls harder up top now but, that is because I can drive the turbo harder as well. I broke the shaft in my HX35 a week before I changed plates so, I dropped in HX35/40 Hybrid we had in the shop and drove for a week on the #10, no other changes. It would flatten out on top and only pull 28lbs of boost. I switched to the #100, keeping the same AFC housing placement and approximately the same plate position, maybe a little forward, and I can pull 33lbs and it runs about 100 degrees cooler holding a steady 80 mph climbing Interstate 70 going West out of Denver.
Right now we have 17 degrees of advance on the pump and it is just a little too much. I get a little flutter out of it at high rpm under WOT. I will back it off a degree or so this weekend and see what I get. |
If I have another p-pump truck which I will it will have a 100 plate in it. I had a 0 plate and didn't like it. In my opinion nothing drives like a p-pump with plate 4000 springs and good timing. I miss it.
What about exhaust temps with a stock turbo? Will they run hotter with a #100 than with a #10? Thanks!
(Post 2585404)
I would assume the stock turbo wouldn't be able to keep up with the #100 plate so, it would be hotter than the #10 but, I didn't get to try it since my stock turbo let go right before I was going to change plates :( |
It all depends on plate position. You can make the 10 fuel harder than the 100 by having it in a more forward position. If the deepest part of the 10 plate is in the same place as the deepest part of the 100 plate, the mid range will be the same between the two, but the 100 will have the better top end.
