'02 4x4 frontend always locked
I was wondering why Dodge made the front end on the '02 4x4's to where they are always locked. Granted it's better than the CAD, but with it always locked the front driveshaft always turns. I've been through 2 u-joints in the last year. I don't even use 4wd a lot. I really think they would have done a lot better if they had put manual locking hubs on it. Just wanted to see if anyone else had as much problems with this as I do. If I had the money, I would convert to manual hubs insetead of this stupid setup that it has now!
Yeah, I need to get that from you. The u-joint was a non greasable joint. But it still would be a lot less wear and tear if it wasn't locked all the time.
It may not have been the factory u-joint in the truck when I bought it. None of the joints I've replaced have had a greaser.
You got the full time locked front end thanks to all the whiners who complained about having to get out to lock the hubs.
Apparently Dodge doesn't like grease fittings, more money in their pockets for parts. Get the regreasable u-joints in the future.
If people are too lazy to get out and lock the hubs, they have no buisness owning a 4wd!!
Hey hey hey. I like being to just reach down and pull it in. I hate getting out and getting all muddy because i got stuck and didnt have the foresight to lock in the hubs.
It is just one of those things, i want strength but i also want ease. Guess I'm not having any cake.
That front design is very simple: no hubs to break or wear out. Fuel economy isn't an issue. It actually last longer when it turns all the time, the splines don't seasaw back and forth and wear out like the old trucks with lock out hubs did.
Your rear driveshaft turns all the time, does it wear out often?
