01 won’t shift under hard acceleration
Help My D-max friends r comming in town and we r going to race and they out number me Ha ha I cant let them win. to get my truck to shift I half to let out of the throttle and it slow's me down big time.
I half to let out of it to like half throttle to get it to up shift and then slowly apply the throttle to prevent it from down shifting
Is it the APPS that is causing my issue?
Check your tv cable, might be a bit too tight.
Mine was the shifting bands. I had to set them,the front one was so loose that the wedge had fallen off into pan.
Does a 01 have a tv cable? what side of the trans is it on? what does it look like and what does it hook to? thanks
Originally Posted by heykw
(Post 2040708)
Thanks I will try to look at tomorrow
easy to adjust...just did mine after putting in the trans go kit. Take off your throttle cable cover, you will see it on the bottom, carefully pull off the white locking tab, then push the cable in to losen and let it push out to tighten, then install the locking tab. Pretty easy.
so does it need loostened or tightend?
The looser the more pedal needed to kick it down, the tighter the faster it will kick down and longer it will hold a gear before up shift...So I would loosen yours. It takes literally 30 seconds to do once that stupid cover is off. So you can play with it to set it the way you like. I wouldn't move it much more than 3 or 4 notches at a time....if this doesn't change it you have other issues in the tranny.
| All times are GMT -5. The time now is 02:10 AM. |
