#0 plate
I like the 100 plate alot better than the 0 for the fuel control on the bottom end. I really don't like the big bellow of smoke with the 0 plate I had. I ran the 0 on a 180 pump and run the 100 on a 215 pump if it makes any difference. I am running alot different timing now and thin washers with a .013 cut head which may make a difference in smoke to.
As gwhammy stated, the #100 has less fueling on the bottom end than the #0 does. The name #100 means bottom end of a #10 and top end of a #0 (your foot is fuel control).
i have found 2 mpg less with the 0 plate under same driving conditions. plus side is a solid .4 better 0 to 60 time checked with the same g-tech on the same road.
Wow, you must have to change your oil a lot! Ever have problems with condensation not getting out of the oil? I'd imagine there would be a lot of error possibilities in such a short trip.
West Coast
07-01-2007 02:32 PM
Rockcrawler
14
06-23-2005 11:40 AM
banks twinram
02-05-2005 10:38 AM
