Whats your Connection ??
Old Oct 24, 2004 | 08:36 PM
dieselminded's Avatar
Exclamation Whats your Connection ??
Im currenty in the process of getting a wireless connection I now have dail-up what is all required for the wireless and is it any good??
Packages*
Down Speed (1)
Up Speed (2)
Monthly Cost*
Basic
1.5Mb -1
512Kbps-2
$26.95
Advanced
2.5Mb-1
768Kbps-2
$36.95
Professional
3.0Mb-1
1024Kbps-2
$44.95
Ill start with basic and work my way up
thanks for your input
DM
Old Oct 24, 2004 | 08:39 PM
phox_mulder's Avatar
Your table got messed up, but if I understand it correctly,
Basic will be about a thousand times better than the dialup you currently use..
phox
Old Oct 24, 2004 | 08:42 PM
28.8 KB now --- 1.5 MB AFTER its like having quadruple turbos
I tried to save the table by adding the 1's and 2's after the upload and download it kind of works
DM
ADD $5 a MTH for STATIC ?? what ever that does I wonder if I need it??
Old Oct 24, 2004 | 09:02 PM
That means your IP number won't change.
Without the $5, you get assigned an IP each time you log on.
You don't need it unless you're running a web server that can't have the IP address changing.
Mine's supposed to be dynamic (changes) but it's been the same since I got the service.
Sprint Broadband Direct wireless.
Doesn't exist anymore as in they're not accepting new customers.
I'm just keeping it till they totally phase it out, then I'll most likely get cable internet.
phox
Old Oct 24, 2004 | 09:23 PM
Not planning on running a web site as of yet so I wont need static
thanks for the millionth time PHOX
they want $300 for the so called kit not sure what it includes Im thinking just the antena they have a seperate list for Wireless Equipment not sure what "router" or any of that stuff Ill need ?? I suppose Ill have to replace my dail up modem card with something diffrent.
Are all routers also firewalls???
there tech people are coming over tomarrow for the test $10 Im out if Im too far from town .
Ill keep this thread updated in case others are interested.
so far it looks like wireless is $300 up front and $26.95 a mth not sure about hiden fees/charges and if additional hardware is required.
I could just go buy the EDGE EZ instead .........................but the ol' lady would kill me
DM
Old Oct 24, 2004 | 10:18 PM
jlells01's Avatar
Here's what I got:
http://www.bandwidthplace.com/speedtest/
Communications 7.1 megabits per second
Storage 871.8 kilobytes per second
1MB file download 1.2 seconds
Subjective rating Awesome
Old Oct 25, 2004 | 12:15 AM
BigBlue's Avatar
I'm running off cable modem. I like it a lot. Tons better than dial up.
Old Oct 25, 2004 | 12:19 AM
joefarmer's Avatar
Chad,
Who's the company that's doing this? I'm interesting in offering wireless out west of columbus too. Thanks!
brandon.
Old Oct 25, 2004 | 07:15 AM
Hannibal's Avatar
I'm using cable from IJ.net through a Toshiba modem and Linksys router and compaq PC cards for the laptops. Works like lightning!
Old Oct 25, 2004 | 08:55 AM
I PASS GAS's Avatar
Just a note. Needing a staic IP does not only apply to running a web server at home, it could be for many other uses. Such as, if you want to run remote desktop connection on your machine at home. I use this and I have a dynamic IP, but I changes very little. However, every now and then I'll go to use it, and that isn't my IP any more. Kinda sucks, but not worth the extra money to me.
Old Oct 25, 2004 | 09:19 AM
DieselDaze's Avatar
Ive got a T3 link here at work and a 3 meg cable connection from home. The home connection is bundled into my cable TV costs, but its around $45.00 p/month.
Currently, the speed I have here at work is:
2004-10-25 10:12:49 EST: 3839 / 336
Your download speed : 3907938 bps, or 3839 kbps.
A 454.9 KB/sec transfer rate.
Your upload speed : 344086 bps, or 336 kbps.
(Upload seems a little slow, )
Rich
Old Oct 25, 2004 | 01:14 PM
ramlovingvet's Avatar
DTR'S Chaplain
163.3 kilobits per second
Old Oct 25, 2004 | 01:50 PM
jthorpe's Avatar
DTR Founder
OC-12 here.
Old Oct 25, 2004 | 02:23 PM
JKM's Avatar
JKM
I guess i have a good connection at 10mbps then? lol
Old Oct 25, 2004 | 03:50 PM
TomW's Avatar
Originally posted by Jack Thorpe
OC-12 here.
