what CB?
Old Jun 5, 2006 | 06:29 PM
BCB's Avatar
BCB
what CB?
I am looking to put a cb radio in my 97 5 speed and was curious what you guys are running and where you mount them.
I was thinking one with all the controls on the mic and mounting it under the seat.
Old Jun 5, 2006 | 07:41 PM
hotdram's Avatar
Run a Uniden PRO520XL CB in the cubby hole in the dash and a scanner in front of the middle seat (like having the weather stations on the scanner, any CB that I found with weather station capability wouldn't fit in the cubby hole).
~Rob
Old Jun 5, 2006 | 07:45 PM
displacedtexan's Avatar
Midland 1000 in the cupholder-
Old Jun 5, 2006 | 07:48 PM
hotdram's Avatar
Looks good man. Saw that in the photo gallery earlier
~Rob
Old Jun 5, 2006 | 07:53 PM
Beamwalker's Avatar
galaxie 93t with twins pumping 150 watts, wilson 2000 mag mounted
Old Jun 5, 2006 | 07:54 PM
hotdram's Avatar
Cobra and Midland both make units like you are talking about.
The Cobra unit, everything mounts out of the way (+12V is hard wired to a source) and all the controls are in the handset:
Cobra C75WXST
The Midland unit plugs into the cig. lighter, but you can take the bottom part off, add a battery and an antenna and you have a portable CB. A neat idea, but not a hard wired solution like the Cobra.
Midland CB
~Rob
Old Jun 5, 2006 | 08:22 PM
~Rob
Thanks, it was one of my hairbrained ideas. One of the better ones
I like they way you have the scanner in yours.
Old Jun 5, 2006 | 09:04 PM
hotdram's Avatar
That was a good idea. I had a 97 Dodge and the engineer that said "hey man, this is a good place for a cupholder" should be forced to suck on the exhaust hose running outside a shop on a diesel dyno day.
~Rob
Old Jun 5, 2006 | 09:13 PM
Hillcountry's Avatar
I have an old GE unit from 1974 (It was my dads...sentimental value) and it is mounted right below the ashtray which has been converted into a switch panel for extra lights and an air horn button. It is hardwired and works well.
Old Jun 5, 2006 | 09:19 PM
Begle1's Avatar
When it comes to CB radios, would you be any better finding an older model than a newer one? For tools and appliances I swear that stuff made before 1980 is inheirently better; do CB's apply to the same logic?
Old Jun 5, 2006 | 10:02 PM
It's worked for 32 years, but that being said, I'm sure there have been major improvements since then. the only thing I can say is that it is built like a tank. All metal and solid. The RF meter is broken so I need to fix that but I like it and it works. I'm sure a better, well mounted and adjusted antenna will make the biggest difference. Just a guess though. Have fun!
Old Jun 5, 2006 | 10:29 PM
BCB's Avatar
BCB
thanks for the replys and the links. i was lookin around and i really like the pc68 elite anyone have one of these? also what antena(s) (i like the 2 antena look) am i going to see (well... hear) the best results with.
hotdram what kind of radio is that in place of your stock AM/FM? thats sharp and i have been look at upgrading the audio and replacing the shortwave radio my dad put in this truck when he drove it.
Old Jun 5, 2006 | 10:35 PM
I have dual Firesticks on my toolbox. They work well.
Old Jun 5, 2006 | 11:53 PM
wcjp's Avatar
The Uniden and Cobra are the same thing. Different color lights. I'm running the 29series Cobra w/weather. I had the Cobra 75 series. Absolutely hated that radio. Sub par rx/tx. The handle is too big for extended conversation. I think for most it's either love or hate with that rig. On my 96' I had a ham radio mounted at the base of the center seat. Avoid the Cobra 75.
Some consider weather on a CB an abomination. I find it very convenient for Jeepin'.
Old Jun 6, 2006 | 04:36 PM
BCB's Avatar
BCB
im sorry i am new to these CB's... but why did you hate that radio?
