Toyota to get the Cummins Rival!!!!
I have just finished up with a Cat Technician working on some of our Gen's and the conversation turned to 3/4 and 1 ton trucks. In his words- - - - - -Some of there Catapillar Technicians are learning the Toyota Way of doing things in there training seminars in the past couple of weeks!!!!!!!!! -------He said that the new Common Rail C7 will be the engine of choice for the new Toyota Tundra!!!!!!!! I can't wait to take a test drive in one of those BEAST!!!! -------Ok start the Flames !! I wonder what the power output is going to be and if the Cat will hold up over time?????
--------Ok so where is yours??????? ------If there technicians are being taught the (Toyota way)----just what does that mean-----they are just trying to get better at dependability?????? I have to beleive that he would know what he is talking about. I'm not going to call him a liar or some joke when he works around and reads the reports that his fellow technicians bring back to the office.
Listen, at any one time we have between 5 and 10 technicians on our payroll, and let me tell you what, some of them are full of enough bull, and ornery enough to start a rumor like that just for fun.
Also, A C7 Cat weighs in right at 1,300lbs. 200lbs and some change more than a Cummins. And it is 7.2 litres in displacement. I don't think it'd fit, and I don't think it'd drive worth a darn if it did with all that weight on the front end.
He stated that they were looking into the weight saving issue already------I brought that up because of a previouse post on here about the weight of the engine. I dont think that fitting that engine in the New Toyota would be that daunting of a task???? Why do you feel that way about the C7????? I hope that this is true and not some fluff, I'm just not going to call someone that I have had a great working relationship with a liar. I have never know this person to lie about anything that he has ever stated pertaining to Diesel talk!
I dont know what y'all think about Toyota, but provided:
1) This rumor is true
2) Cat can put their best foot forward with the C6/7
3) Toyota truly builds a truck for that engine,
Then, that would be a good combination.
However, the three criteria in mentioned above could be said for any manufacturer starting out with a new design/combo.
Rich.
Rich.
Here are the spec's on the Truck Engine Listed on Cat's Website!
Specifications
Cylinders In-Line 6
Bore/Stroke 4.33 x 5.00 (110mm x 127mm)
Displacement 7.2 L (441 cu in)
Weight 1295 lb (588 kg)
Horsepower 190 to 350 @ 2400 rpm
Torque 520-860 lb-ft @ 1440 rpm
Here are the spec's on the New 6.7L Cummins!
Specifications
Cylinders In-Line 6
Bore/Stroke 4.21x4.88 (107x124mm)
Displacement 6.7 L (408cu in)
Weight ???
Horsepower 305 @ 3,000 rpm
Torque 610 @ 1,600 rpm
Someone please fill in the weight spec's on the Cummins!
I dont see where or why the CAT would not fit in our engine bay---none the less the new Tundra!!!!
Specifications
Cylinders In-Line 6
Specifications
Cylinders In-Line 6
Weight ???
At the moment, Toyota is just listing three engines for their 07. 5.8L V8 confirmed and suspected a 4.7L V8 and a 4.0 L V6.
If they move up to a heavier duty truck, they could easily get rid of the two smaller engines for a diesel.
This is the spec on the C6:
You can read more about it HERE
I provide this on the C6 as Im guessing (and just a guess) that the two engines are going to weigh in pretty close to each other?
Rich
I-6, 4-Stroke-Cycle Diesel
Bore (mm, in) 105 mm, 4.13 in.
Stroke (mm, in) 127 mm, 5.00 in.
Displacement 6.6 liters, 402.8 cu. in.
Aspiration Turbocharged/ATAAC
Rotation (from flywheel end) Counterclockwise
Cooling System Liquid
Weight, Net Dry 525 kg, 1157 lb.
(approximate kg, lb)
88-186 bkW/120-250 bhp 2200 rpm
Rich
Specifications
Cylinders In-Line 6
Specifications
Cylinders In-Line 6
Weight ???
Specifications
Cylinders In-Line 6
Specifications
Cylinders In-Line 6
Weight ???
860 ft/lbs at 1440 is insane Especially if they can put in into a lighter pickup than a dodge.
