Took a break, now I'm back
Hey folks,
I took a break from the forums for some online classes I absolutely had to get done for work but now that I'm starting to wind down I've a bit more free time and decided it was time to stop by.
I'm really liking the new look on the forums, the subtle changes and how everything is in order.
Just wanted to stop by with a quick "Hi" and do some more browsing.
-Kris
-Kris
Laughing ... hey, its been a while!
I'm taking an online class for CCNA .... Cisco Certified Network Associate. It's a cert I need for work and there are some computer labs I need that go along with it. Making routers talk to each other, the different protocols, etc..
HMX,
Have fun with those courses. I got my CCNA back in 1996. Things were a bit different back then but at that time, Cisco ran some of the best courses out there. When I got my ceritification, switched Ethernet was was just coming on the scene. I worked in a shop that was 95% token-ring. We were also putting our first collapsed backbone and some of the first fibre in Alberta outside of the telcos. Our collapsed backbone was ethernet. We could bridge token-ring to token-ring or Ethernet to Ethernet but had to route between the different topologies. Some of the stuff we had to learn , like how to make crossover cables or how to open a port in a MAU (token-ring) are now dead skills. The one thing that really killed me was subnet masking. I memorized the formula and did the math mechanically but the theory about why I was doing what I did just never stuck. Good luck on those courses, they will never do you harm in the future.
This wil give you a chuckle. Most of our WAN connections were 56 Kbps and our Netbios traffic shared those connections with the IBM 3174's for the IBM 3270 terminals (I forget what protocols the mainframe stuff used).
Here is another dead skill screwing a tap into the lump on a thicknet cable. Tracking down missing terminators on thinnet runs wasn't much fun either....
HMX,
Using DEBUG and the "g=c800:5" commands to access the hard drive controller before using "PREP" and "PART" .... back in the days of MS-DOS 3.x before they switches to "FDISK" and "FORMAT".
Somewhere I think I still have a bootable 5.25" floppy with MS-DOS 2.1 on it, and mounted on my wall in a frame is an 8 inch floppy disk, right next to a Pentium 60 board and CPU, and the Hayes V-series SmartModem 9600 baud and Zenith 300 baud modems .....
And yeah, sub-netting is a PITA.
J Lent
10-07-2009 06:50 PM
Chip
14
06-21-2009 03:59 AM
Red3quarter
09-06-2008 11:56 PM
JoshPeters
04-03-2005 08:13 AM
