snow plow help
Old Feb 16, 2010 | 09:26 PM
jj3500's Avatar
snow plow help
Anyone members out there have snow plows on their trucks? I just picked up, new to me, an older truck with snow plow. I disconnected the plow, let it sit for two days off truck. I re hook it up, now I can't get it to pivot left or right. It goes up and down no problem.
any ideas? water in hydraulic lines?
Old Feb 16, 2010 | 09:42 PM
megacabdad's Avatar
What kind of plow is it?
Make sure all your electrical connections are greased and plugged in tight.
Also that you have enough hydraulic fluid in the pump.
Old Feb 16, 2010 | 09:56 PM
jj3500's Avatar
Fisher speed cast. separate pump off of motor. Fluids are good...just topped off other day.
plow jerks in those directions i move joystick to. It seem it just gets stuck.
No plug ins. Just plug in the male/female hose fittings and its hooked.
Old Feb 16, 2010 | 10:06 PM
megacabdad's Avatar
OK.
It does sound like there could be air or moisture in the lines then...
Old Feb 17, 2010 | 06:19 AM
Hvytrkmech's Avatar
So this is a mechanical hydraulic plow with a pump on the engine correct? I check fluid level and look lots of foam in the fluid. Is the pump making screeching noises when you try to angle it? I would remove all the angle cylinder hose lines, then manually push the plow end to end and watch for the fluid that comes out, then refill with fluid and run the plow bumper to bumper. These older Fishers called for Dexron ATf for fluid.
Old Feb 17, 2010 | 09:41 AM
jj3500's Avatar
Yes, mechanical pump on motor.
Pump is not noisy. At this point, I think there is moisture or fluid is just contaminated.
Plow is new to me...not sure of fluid condition...age etc.
Thanks though for suggestions.
Old Feb 17, 2010 | 06:15 PM
megacabdad's Avatar
I'd try a complete fluid exchange on it then if you have no idea what's been run in it...at least eliminate that from being the problem.
Keep us updated!
Old Feb 20, 2010 | 06:24 PM
jj3500's Avatar
Well, I figured out the problem. Today was a little warmer, 40 degrees. I was out there looking at the fittings. One of the two hoses was only 3/4 inserted. I guess the night I was trying to hook it up, the snow/ice got packed in the fitting too. Works fine now.
Thanks for all your input.
Old Feb 20, 2010 | 07:15 PM
megacabdad's Avatar
Glad it was an easy fix!
jukenut
Feb 21, 2013 08:47 AM
arbor x dad
Feb 14, 2011 01:56 PM
Hoss
Dec 10, 2005 02:30 AM
radracing
Oct 30, 2002 03:57 PM
