punching bag stand?
Old Mar 6, 2007 | 04:45 PM
nchapa's Avatar
punching bag stand?
Does anyone have a heavy bag stand? what do you all think of this, i want one that wont move around.
http://store.everlastboxing.com/out-...oxing-gym.html
do you think that base really holds 50 gallons, will that be enough to keep it from moving around?
Old Mar 6, 2007 | 04:47 PM
Hoss's Avatar
Thats MR Hoss to you buddy!
If you punch as hard as me then nothing short of a freight train will hold it still.
Old Mar 7, 2007 | 08:15 AM
berner's Avatar
Ok. Out with the calculator. A gallon of water weighs 10 lbs. A cubic ft of water contains 6.24 gallons, so it weighs 62.4 lbs. So... the base looks like it's about 4 ft x 3 ft x 8" high. That's 8 cubic ft. Multipied by 62.4 lbs = 499 lbs. so I'd say they aren't BS'ing. The thing weighs 135 lbs. So you're lookng at 635 lbs total weight. It looks like a nice unit with the speed bag mount as well.
Me, I just hung my heavy bag from a floor joist and rattled the house. Then I got lazy. I haven't hung it up since we moved. I do kick it once in a while when I trip over it.
Old Mar 7, 2007 | 09:32 AM
t-boe's Avatar
Nice thing about that particular model is that you can put it outside so it doesn't clutter up the house. I've been considering that one myself.
Old Mar 7, 2007 | 11:22 AM
Hoss's Avatar
Try 8.33 pounds for a gallon of water.
Also, a cubic foot is 7.48 gallons, not 6.24.
If it holds 50 gallons like he said, then it's 416.5 pounds plus the weight of the machine itself.
Old Mar 7, 2007 | 01:02 PM
berner's Avatar
Well I sorta stand corrected. I was out by 0.01 lbs/cu ft. If you use REAL gallons, ie. imperial, it's 6.23 gal/cu ft. and 10 lbs/gal. It's still 62.3 lbs per cu ft. whichever system you use.
Back to nchapa's original question: guessing at the dimensions I'd say yes it does hold 50 gal.
fazmig
Mar 3, 2015 02:49 PM
Lonepine78
Sep 25, 2013 10:57 AM
PZM123
Feb 5, 2007 06:01 PM
xj2extreme
Apr 3, 2003 11:06 AM
JoeDiesel
Jan 9, 2003 01:42 PM
