Pipe staging
Pipe staging
At work we commonly use pipe staging where we can't get a lift into easily (electrician). Or because someone is too cheap...
Anyhow, latest one is reworking some lights and adding ceiling fans in a gymnasium. I usually don't have much problem with staging, besides it being a pita to set up, but we already have 5 tiers of 5'? Staging to get to the lights. Will most likely need another 2 to get up to where the fans are going. It's already a bit shaky for the work we have to do, unless I'm just getting old. What are the safety requirements for using staging on wheels? We have outriggers that add a few feet to the base, I think is required for anything above 4 tiers.... These are pretty standard 5x5x7 sections. Thanks!
When it comes to scaffolding, safety and training are paramount. But it is absolutely critical to be aware of its limits. The Scaffold Industry Association, Scaffold Contractors | Scaffold Manufacturers | Scaffold and Access Industry Association offers training courses. Years ago, I purchased Upright lightweight aluminum scaffolding for a long term project our company took on. Training was provided to everyone involved with the erection and utilization of the scaffolding. Outriggers were used and wheels locked when utilized.
I recommend you check out the OSHA website or a very informative publication: "A Guide to Scaffold Use in the Construction Industry / OSHA 3150." (You can download it for free at http://www.osha.gov.)
OSHA safety provisions note that a "competent person" must oversee the scaffolding's erection and dismantling and inspect it for visible defects before each day's use and following any occurrence of possible damage to any component. Is this scaffold rented or company owned. It appears you are in Mass. Is the work taking place in Mass?
Be safe and never short the bracing. Use bracing at all points provided and add extra braces if needed to insure stability. You have not provided enough info regarding the type (heavy pipe tube style with wooden planks perhaps) but nonetheless, you would be best served by checking out the OSHA doc noted above for the best help.
As far as lifts go, their heavy base weight is typically an issue in gymnasiums. We always used the Genie AWP series lightweight lifts where damage to the flooring was a concern. This lift allowed us to get more work done vs scaffolding.
Seriously? The labor to instal, move and take down scaffolding will be higher than renting a lift, not to mention your time climbing and staging your tools and materials.
I'd talk to your boss to see what the estimator was thinking...just my .02
The estimator is the boss, who doesn't think past the green sometimes (time and material job). Staging is owned by us (company) and is stout with the ladder built in to it.
Ended up finishing the job today, with staging. Thank god for young willing help. Wasn't too bad, platform height was under 25' but i expressed its the last time using it for more then repairs. Was a pain running conduit along beams, hanging fans, pulling wire... Etc off a platform that needed 2 people to roll around, sometimes twice to hang one piece of pipe.
dzlfarmboy
03-31-2007 12:33 AM
Jordan5687
02-14-2007 05:00 PM
PADZZ
02-09-2003 08:33 AM
