Need Help With Old Johnson
Old Nov 21, 2006 | 07:08 PM
SupaDupa's Avatar
The outboard on my boat is giving me some trouble of late. When she's cold, she'll fire right up and run like a top. If I shut her down to fish a spot or whatever, if I don't wait long enough for her to really cool down, she won't start or else it takes forever to get her running. She ran fine all summer and this started about 2 months ago. She's a 50hp, oil injected, 2 cylinder, 2 cycle, counsil steering. Any ideas anyone??? I keep her in the garage and do all normal maintenance.
Old Nov 21, 2006 | 07:29 PM
madhat's Avatar
Administrator/Jarhead
No boat expert by any means... But I've heard this one before. I think it has something to do with cooling, (water path) and the oil delivery. Fresh or salt? I'd make sure that you were getting/expelling water normally, and check the water delivery path.
Once again, not a boat genius...
Old Nov 21, 2006 | 07:30 PM
madhat's Avatar
Nel, where's your MIND!!!
Old Nov 21, 2006 | 07:32 PM
CIN'S DODGE's Avatar
Mrs. missin on a mission & keeper of the can
Yeah I was thinking the same thing Madhat.(nonono)
Old Nov 21, 2006 | 07:34 PM
nelrod's Avatar
hey, I'm not the one asking these questions.
Old Nov 21, 2006 | 07:39 PM
Think outside the gutter on this one.It has to do with a B-O-A-T-S.Remember we have to keep these threads clean..02 Cin
Old Nov 21, 2006 | 07:47 PM
boostjunkie1's Avatar
Vapor Lock-----------This is what it sounds like!! The plastic Bowls that Johnson used on there Carbs are known for heating up really bad and causing the Fuel to Vaporize after you shut the engine down. I have had to gave many, many, Fuel Bowls replaced on one of my older 1999 200 HP Johnson's!! Fix= Replacement of the Fuel Bowls, adjustments of the reeds, and carb adjustments. I had the exact problem happening day in and out with the old Johnson. Push in the Choke while starting and hold it in for a couple of seconds. Once you put the boat in gear you will have to push in the choke again to get the boat on plane--------well this is what I had to do to get my 1999 R91 Ranger to plane out without killing the motor!!!! Good Luck------Make sure that you take the Engine to a Johnson Specialist that has been in the business a while!!!
Old Nov 22, 2006 | 10:49 AM
Raspy's Avatar
Sounds like vapor lock. When starting it while still warm DO NOT use the choke and give it as much throttle as possible. If you have a remote shifter move it to the throttle only position, out of the transmission gate, and give it full throttle to start. Also, old gas may be part of the problem. Old gas these days can be just a couple months old. It may be time to do some carb work.
Wetspirit
Old Nov 22, 2006 | 11:25 AM
cskal's Avatar
Yeah, no mention of a dinghy...
Old Nov 22, 2006 | 12:36 PM
Hoss's Avatar
Thats MR Hoss to you buddy!
This thread is just begging for someone to mention Viagra.
Old Nov 22, 2006 | 12:39 PM
Shovelhead's Avatar
Administrator / Scooter Bum
I was wondering who would be the first to post that.......
It HAD to be Hoss........
Old Nov 22, 2006 | 12:50 PM
I noticed lol
Old Nov 22, 2006 | 01:39 PM
madhat's Avatar
Man, there have been some questionable posts going on lately... Full moon?
Old Nov 22, 2006 | 04:43 PM
jrs_dodge_diesel's Avatar
Time to put this one back on track.
Dodgezilla
Nov 6, 2011 04:13 AM
chariotdriver
Oct 18, 2008 10:50 PM
Mopardan
Jun 20, 2006 10:26 PM
tool
Jun 22, 2004 12:29 PM
MnTom
Jun 4, 2003 07:02 AM
