Mystery gas bottle (pressure)
What is it? or more specifically what kind of product would it have contained?
looks like a high pressure gas bottle. Bung on top is solid with no ability for the high pressure gas to escape. Only letters I could find was "Dalmine" stamped in the bottle near the top.
When full, someone would have to unscrew the top, open to atmosphere, screw it on to whatever appliance it was used on then pressurize it...
To make acetylene one needs to mix water with calcium carbonate.... Hmmmm it does have some sort of black substance in it....
I picked this thing up at a mine site that never really got off the ground.
The bottle:
the dump:
The bottle:
the dump:
That would be a Tenaris Dalmine cylinder. They are color coded to identify the gas or agent that they contain. That cylinder looks like it has black paint on it in places which indicates that it is or was filled with N2 (nitrogen) or maybe breathable air as per their data sheets. That tank should have several stamps (codes) located around the top that designate several identifiers. It may be pressurized at 300 bar and I do not recommend removing the threaded top.
How would the nitrogen or whatever been removed from the bottle? there is no valve...
I'll take the wire wheel to it a little later to see if I can find any other stamps. I have had the tops off both bottles I have (no pressure)
These have been sitting out for quite a number of years. I would place the site to being late 60's to early 70's just based on the other stuff found around there.
Interesting....
What do you plan to do with the cylinders?
Only plan I got is to figure out what they could have been used for. Then at some point they'll land in the scrap pile.
Every cylinder in that pile has the bung threaded back in. If they came under pressure they would have come with a valve and this steel threaded bung dangling off the side. After use someone would have removed the valve and threaded in the bung...
could be an accumulator.
Nope. This is a bung. A solid piece of steel that is threaded at the end that goes into the bottle. On the other end it tapers to a flat piece with a hole in the middle. (something you would put a wrench on to tighten) put a string on to keep from loosing. I look at the tab with a hole in the middle welded to the side of the head on the tank and can't help think those two are related...
edit:
Took the wire wheel to the bottle. No other stamps or markings either top or bottom other than the Dalmine
edit:
Shoot it from a distance with a high power riffle. If it explodes it was flammable if not it was most likely empty
Think I got it figured out....
They are mercury flasks. Judging by the quantity of flasks laying about there is a heck of a pile of mercury on that mountain...
