Household Electrical Question
Ok, this is for any professional electricians we have around here...
I'm installing three new appliances in our kitchen, DW, disposal and over the range microwave. The house hasn't had these in the past so I've upgraded tge service panel to accommodate the new circuits and am pulling wire this weekend
Question is :
20 amp dedicated circuit 12-2 with ground for microwave
Sound good?
Disposal and DW sharing a 12-2 line on a 15 amp circuit..
This one I'm unsure of.
Gas range's electrical needs will share the countertop outlets 15 amp circuit
Refrigerator is using existing 15 amp circuit shared with single ceiling light
Anyone see potential issues there?
It would simplify things if the stove and microwave shared a circuit
Question is :
Sound good?
Stove would draw an amp for lights and clocks unless it has some kind of a freaky electric self cleaning deal in it, which I doubt. Wouldn't be a problem sharing with the microwave.
(edit) Are you sure the dishwasher is only needs 15 amps at 120 volts. Might have a heater in it. I think I would split up the DW and disposal anyway.
I usually wire 20A, 240V, (split at the devices) to quad outlets, one leg for each duplex set for counter top. Most counter top appliances draw a lot of juice. Wire would be 12/3 w ground.
DW manual says 120 at 15.? Haven't bought the disposal yet
They just finished stripping the walls and it looks like the previous counter top outlets are all on one 30 amp circuit but since it worked so far,
Don't think I'm gonna change them following the
If it ain't broke philosophy
You need 2 separate circuits.
Like I said, modern adequate kitchen wiring is several 20 amp circuits. The easiest way to do that with minimum materials is as I described.
As long as you're tearing the place all apart, why not spend an extra $50 and do it right.
Ok, so here's what I've run:
Circuit A: existing **** and tube, 15 amp breaker
One duplex countertop outlet and light over the sink-outlet is located where it won't be used often
Circuit B
12-2 nmb w/ground 20 amp breaker- disposal
Circuit C
12-2 w/ground, 20 amp breaker
4 countertop outlets, one is duplex, and fridge, first outlet inline is GFCI
Circuit D
12-2 w/ground 20 amp
Stove and MW
Curcuit E
Existing **** and tube 20 amp to pantry countertop outlet then 12-2 to pantry ceiling light and kitchen ceiling light with switch legs off each light
Circuit F not yet run
14-2 w/ground 15 amp
Dishwasher( will be run during installation
Sound good??
Circuit B
Circuit C
Circuit D
Stove and MW
Curcuit E
Sound good??
Circuit B
Circuit C
Circuit D
Stove and MW
Curcuit E
Sound good??
Circuit B
Circuit C
Circuit D
Stove and MW
Curcuit E
Sound good??
White02Sport
Oct 6, 2002 07:11 PM
