Here's one for ya....
Old Feb 21, 2003 | 11:07 AM
TPilaske's Avatar
http://www.cyberglass.co.uk/assets/Flash/psychic.swf<br><br><br>Enjoy!<br><br><br>Tony
Old Feb 21, 2003 | 02:15 PM
DieselDaze's Avatar
Re:Here's one for ya....
I ran the code passed some of the guys here at work, crunched the numbers using our HP N4000 HP/Ux Unix Cluster and came up with the following.<br><br>There are numbers that will never be obtained using the formula given.<br>However, there are a certain set of numbers that will be obtained everytime regardless of wich to numbers you originally choose.<br><br>As a result, you can &quot;predict&quot; wich symbol the little blue ball is going to show next by looking at one of the few numbers that are possible.<br>One of these numbes is the number 81.<br>Take a look at the number 81. <br>Each time you &quot;play again&quot; the symbol beside 81 changes. <br>That symbol will be the next symbol to be displayed in the little blue ball.<br><br>Yes, this is what a bunch of techno geeks do on a lunch hour.<br> <br>Rich
Old Feb 21, 2003 | 02:38 PM
SunnyBeebs's Avatar
Wow, how much time did you guys spend on this? ??? Every number is a product of zero! Just look at the zero and it will always be the same symbol that is displayed in the crystal ball. ;D
Old Feb 21, 2003 | 02:40 PM
TPilaske's Avatar
and every 9 numbers after that... :
Old Feb 21, 2003 | 03:34 PM
DieselDaze's Avatar
[quote author=SunnyBeebs link=board=10;threadid=11256;start=0#107484 date=1045859930]<br>Wow, how much time did you guys spend on this? ??? Every number is a product of zero! Just look at the zero and it will always be the same symbol that is displayed in the crystal ball. ;D<br>[/quote]<br><br>It took one of our engineers a few minutes to type up the program to run the calculations... Probably took him longer fixing all the type-o's than it did to write the code. :<br>After compiling the code, it only took about 2 minutes to generate all the possible numbers that could be produced using the formula given. <br>Once the numbers were provided, it recalc'd them to find a pattern.<br>I used the number 81 as an example.<br>The entire process from start to finish took less than 10 minutes.<br>(Thats not counting all the interuptions from this thing they call &quot;work&quot;. It sure gets in the way! )<br><br>Rich
Old Feb 21, 2003 | 04:50 PM
TPilaske's Avatar
<br><br>I hate it when &quot;work&quot; get's in the way.... :
Dieseldude4x4
Dec 23, 2002 08:56 PM
Bushy
Nov 16, 2002 10:56 PM
Dieseldude4x4
Oct 17, 2002 04:58 PM
DarrellB
Oct 17, 2002 07:59 AM
