Help needed installing Sony CDX L250 in 70 340 Duster
Old Feb 4, 2004 | 09:36 PM
moparguy's Avatar
Question Help needed installing Sony CDX L250 in 70 340 Duster
The Ol Duster is about to become a daily driver and I've picked up a Sony CD unit off E-bay, however it didn't come with installation instructions, only the wiring harness.
I believe all I need to identify is the wire for switched power and unswitched. No need for most of the wiring harness.
So, if anyone can help with either sorting out the harness, or a link (didn't find what I need with Google so far) I'd be in your debt.
Thanks, RJR
Old Feb 4, 2004 | 10:04 PM
phox_mulder's Avatar
Here's a link at sony, if you put the model number, CDX-L250 and ask about manuals, it gives you a link to the owners manual (PDF)
It's a start.
http://products.sel.sony.com/SEL/ser...elec/caraudio/
phox
Old Feb 4, 2004 | 10:13 PM
dodgeram's Avatar
usually on most decks the thick yellow one is the constant power and the thinner red one is the switched ignition power ................ black is ground
Old Feb 5, 2004 | 06:52 AM
moparguy's Avatar
dodgeram, thanks, that's the info I'm looking for.
Jerry, if the colors don't match up with dodgerams suggestions looks like I'll be using your link.
Thanks guys, RJR
Old Feb 5, 2004 | 07:00 AM
JKE's Avatar
JKE
dodge ram is correct...inline fuse the yellow. wire to any constant with switch off....red to switch on....small blue wire is for power antenna and/or remote on for an amp. you may have more than one blue wire...they are the same thing. You are home free....JKE
Old Feb 5, 2004 | 07:04 AM
Shovelhead's Avatar
Administrator / Scooter Bum
Here's some info from that site.
16 pin connector
Pin Number/ Wire Color/ Function
1 White Left Front Positive
2 Green Left Rear Positive
3 Violet Right Rear Positive
4 Grey Right Front Positive
5 Blue/White Amplifier Remote
6 Blue Antenna Remote
7 Red Accessory 12 Volts
8 Black Ground
9 White/Black Left Front Negative
10 Green/Black Left Rear Negative
11 Violet/Black Right Rear Negative
12 Grey/Black Right Front Negative
13 Sky Blue Telephone Mute
14 Orange/White Illumination
15 Not Used Not Used
16 Yellow Constant 12 Volts
9 pin connector
1 Not Used Not Used
2 Black Ground
3 Grey Right Positive
4 Grey/Black Right Negative
6 Red 12 Volt Switched
7 Yellow 12 Volt Constant
8 White Left Positive
9 White/Black Left Negative
bennydodge
Apr 27, 2011 12:19 PM
piperca
Mar 21, 2006 12:31 PM
Journier
22
May 21, 2005 09:09 PM
sherod
Sep 18, 2004 08:33 AM
USMC64-70
Sep 10, 2004 06:28 PM
