Fuse Warning
Old Aug 3, 2007 | 04:41 AM
AlpineRAM's Avatar
Exclamation Fuse Warning
I just got a forwarded fuse warning from GM about some fuses from aftermarket companies.
Quote:
> Subject
> > Warning to other stores; wiring damage due to junk aftermarket fuses
> > We have now had two vehicles come into our department with extensive
> > wiring harness damage. Both of these vehicles had a replacement 15
> > amp fuse instead of the GM fuse. The fuse does NOT “pop” causing
> > the wiring harness to catch fire. The fuse has a clear, hard
> > plastic blue body with the amperage stamped into the top there is no
> > white paint on the fuse. There are no identifying marks on the fuse
> > to tell who is making it. The fuse is distributed by Harbor Freight,
> > I attached a picture of the box of fuses. Your dealers should look
> > out to make sure that suspect wiring problems are not caused by
> > these defective aftermarket fuses. The 15 amp fuse on this
> > particular truck did not “pop” even at 50 amps. The fuse in the
> > second picture still tests “good” even after a direct short across
> > the battery. We tested six of these fuses and none of them pop.
/QUOTE
I do hope that none of you have this kind of junk in their trucks.
AlpineRAM
Old Aug 3, 2007 | 04:50 AM
Murf's Avatar
Not to discredit your post Alpine, but WHO buys fuses from Harbor Freight?
They're good for jackstands and cheap hand tools, but fuses?
Carry on!
Old Aug 3, 2007 | 04:59 AM
qwest's Avatar
????? If you can't trust a fuse, do you want to trust a JACK STAND ????
Old Aug 3, 2007 | 05:16 AM
AlpineRAM's Avatar
Murf: That's just a mail that I got from GM Europe as being forwarded from GM US as a service bulletin. I don't know who would buy what where- wrong side of the pond. I know that over here if you buy a fuse at the gas station (Night, rain, blown fuse situation) you get the cheapest junk at a horrendous price.
I think it's well worth to check (takes only some minutes) and change every suspect fuse (costs only some cents) to avoid those possible troubles.
qwest: You do want to be able to trust your jackstands?? Wussie
Old Aug 3, 2007 | 07:19 AM
MikeyB's Avatar
Harbor Freight does have cheap LED flashlights!
Let me guess, fuses made in China??
MikeyB
Old Aug 3, 2007 | 09:27 AM
LOGAN's Avatar
Muted User
i am going to replace all the fuses in my truck here before too long, previous owner installed 1/2 of them in the wrong sizes, i only use good fuses cause my truck burning to the ground is very high up there on my "crap i dont need right now" list.
Old Aug 3, 2007 | 02:07 PM
halfpint23's Avatar
How do you TELL if you are getting good fuses - I mean EVERYTHING is chicom crapola nowadays, is there even such a thing as "Made in USA" good parts?
Old Aug 3, 2007 | 02:17 PM
DaveB.inVa's Avatar
Use some good BUSS (Bussman) fuses!
Old Aug 3, 2007 | 06:37 PM
dj_souvlaki's Avatar
i actually had the exact same thing happen to my bosses jimmy.
AlpineRAM's Avatar
I think you can test some of the fuses you buy in a big pack by simply using them for shorting a battery. If they weld together and still have continuity like the ones in my first post you know what to do with the packet you bought.
If you want to go a bit bigger you can rig something with bulbs (to use the power) and a fuse holder. EG a 5A fuse should work with a 60W lamp but blow with anything above 60W (maybe use an H4 bulb, usually they are 55W and 60W for each filament)- so the 5A should hold one filament and blow quickly if you use both.
AlpineRAM
Old Aug 3, 2007 | 09:39 PM
dodgeguy71's Avatar
That's just funny!! and so so true!!!
Old Aug 4, 2007 | 08:24 AM
MikeyB's Avatar
Just talked to my Dad. He has a bunch of those Storehouse fuses. So he's rigging a test fixture with 60-100w light bulbs and will also do some direct short tests.
MikeyB
Old Aug 4, 2007 | 05:10 PM
CowboyDave's Avatar
MikeyB
First thing I said too.
Old Aug 4, 2007 | 11:08 PM
Timmay2's Avatar
First thing im gonna say is if youre shopping at harbor freight you deserve to have your vehicle burned.
Tough love.
Old Aug 5, 2007 | 01:35 AM
Haulin_in_Dixie's Avatar
Very interesting and may be the answer to what I have been experiencing. I purchased a 1997 truck with some wiring problems. After fixing the wiring I discovered that the reason the interior light did not work was that the IOD fuse a 15 amp was burned out.
So I changed it and had lights for a day or so then they went out again. I kept digging and digging at the schematics and found that the IOD fuse feeds directly from the 50 amp fuse in the engine compartment box. The lights do no work the 15 amp fuse is good as is the 50 amp. There is no power to either side of the 15 amp fuse. I have previously decided that the wire in the harness has to be burned out. This may be why.
