Final Reminder- Xtreme 4x4 this weekend
This is just a friendly reminder to watch Xtreme 4x4 on the Spike Network this weekend (1:00pm Eastern, both Saturday and Sunday. Yes the show will feature Banks products, but there will be a lot of interesting information, along with coverage of the KORE truck that ran the Baja 1000. I think you guys will find it interesting. Next weekend (March 12-13) the show will continue on the same project vehicle with suspension upgrades and a towing and off-roading test of the vehicle. I had a chance to preview the show yesterday and it really is fun to watch.
Peter Treydte
Banks Power
Peter Treydte
Banks Power
Re: Final Reminder- Xtreme 4x4 this weekend
Peter Treydte
Banks Power
Peter Treydte
Banks Power
I'm sure others will want to know your answer to this question also. Since that turbo is electronically controlled, how will that work with all the various boxes that people have that are not the Six Gun?
That Intercooler looked like it was on steroids compared to the stocker. Sweet! Are the inlet and outlets, and tubing also larger than stock. Looked like it on camera. Is that what it takes for the High Ram to make an appreciable difference? In that setup, how much HP or TQ does the High Ram add? Tks.
Originally posted by HOHN
Grid heaters are turned on with outside air temp, not inside-- if I am correct.
jlh
jlh
From the FSM:
"The wait-to-start indicator gives an indication to the vehicle operator when the diesel engine intake air heater is energized in its preheat operating mode."
"The IAT provides an input voltage to the Engine Control Module (ECM) indicating intake manifold air temperature. The input is used along with inputs from other sensors for intake air heater element operation, for engine protection, fuel timing and fuel control."
With very large injectors I see my water temp drop down to 140F while idling with outside temps under 25F. However this doesn't seem to affect high power situations since I've dynoed at 35°F outside temp.
BTW, my tivo recorded "Xtreme 4x4: Banks Cummings" Would someone tell them they have an extra G floating around??
brandon.
brandon.
brandon.
brandon.
~Rob
brandon.
brandon.
I always thought that extra Gs were a good thing.
Originally posted by Smokeitup
peter
Does Banks make a similar setup for the 12V, and is it available up here in Canada?
peter
On a side note, how about Jessi
You could always check www.bankspower.com
