-   Other (https://www.dieseltruckresource.com/forums/other-94/)
-   -   Factory Anti Spin Differential? (https://www.dieseltruckresource.com/forums/other-94/factory-anti-spin-differential-316516/)
6cylinders 02-09-2014 04:30 PM
Are factory limited slip's worth spending the money on?
Dodge wants $300 something for the anti spin on the 2014 Ram 1500 diesel.
Is a guy better off having an aftermarket air or electric locker installed later?
torquefan 02-09-2014 10:15 PM
I think for the little bit of money it costs to add it to the order, I'd definitely go for the factory one. It will be much better than simply having an open differential. After trying it, if you decide you still need something more, you can go for an aftermarket selectable locker.
samboats 02-10-2014 09:07 AM
You should definitely get it. IMO it will be the best money spent on options.
patdaly 02-10-2014 09:40 AM
That is a given, should be 100 percent standard on any diesel truck. Most factory limiteds work pretty doggone well, and 300 bucks is a steal.
Are they actually letting you order the diesel option now?
Fiftygrit 02-10-2014 10:28 AM
I got it on my 06 when I ordered it and Im glad I did.
RAMRODD 02-10-2014 10:54 PM
The factory limited slip works very well on the 3500's 300 is very reasonable!
Jim Lane 02-11-2014 11:24 AM
Wouldn't changing the differentials yourself void your powertrain warranty?
Sure wouldn't want a new truck without one.
6cylinders 02-13-2014 12:40 AM
Thanks for the replies, yes $300 is a bargain if it works.
DIESELWRKS 02-14-2014 03:41 AM
its the same rear diff on a 2014 hemi 1500. go test drive the Hemi on a rainy day.
oldsmobiledave 02-14-2014 10:09 AM
my experience
Offroad driving without posi is "stuck" waiting to happen. Best $300 you will ever spend on the truck.
Rednecktastic 02-24-2014 10:08 PM
I wouldn't have one without it but I do go off road occasionally, nothing serious though.
Only downside is I believe the fluid wears faster and there are more mechanical parts that can break.
Keep in mind it isn't a locker, but it does work.
SIXSLUG 02-24-2014 10:20 PM
You are buying a truck, right?
Get it.
patdaly 02-25-2014 08:54 AM
Get it.
Best answer yet. [coffee]
Rednecktastic 02-25-2014 10:43 AM
Only 2 reasons I could think of not to get one would be a fleet on road delivery truck. Or if I wanted to install a locker of some sort for an offroad trail truck I was building.
Cujo_07 02-25-2014 10:50 AM
I've had one on every truck I've had, worth the money. Now with that said its amazing how many trucks are on dealer lots around my parts without it. I don't understand.
