Electrical question
Old Jul 11, 2006 | 09:01 PM
Mexstan's Avatar
Originally Posted by ajpulley
However, where static discharge or lightening is of a concern, you may want to consult the National Electrical Safety Code (not the National Electric Code) and moreso NFPA 77. If in doubt, I strongly suggest contacting a professional in this field to answer this question.
AJ Pulley
MA Licensed Electrician
MA Electrical Instructor
Member International Association of Electrical Inspectors
Thanks, but you forget where I am located. In this case I can't even find a national code, nor would anybody care if there is one. I am my own professional when it comes to grounding static electricity, hence my questions here. A friend of mine is one of the few electrical consultants here and the only thing he can come with is some stuff on pulsed EMI - ESD (electrostatic discharge). I read the entire technical article and it is quite interesting. He believes in overkill and has suggested a #4 wire, but I know that this is way overkill, especially as the situation applies strickly to indoors and there will be no lightening strikes.
A clue to what is required for wire size can be found in what many aircraft manufacturers provide for a ground jack on the aircraft. It is only a modified 1/4 inch audio plug and the wire terminal on those things is pretty small.
One small change that I have decided on, but this should not affect anything, is that I am now going to tie the building electrical grounds into this as well.
All electrical wiring in the building will be #12, so see no reason why I can't use a #12 ground wire from the rebar to the static discharge ground studs in the floor and to the grounds on every plug. Anybody see a problem with that?
Thanks to all of you who have contributed to this disccussion.
Old Jul 11, 2006 | 10:02 PM
ajpulley's Avatar
I do see your location now.
The size conductor that ties all the groudning electrodes together is based on the size of the electrical service, or main disconect. I would not use 12AWG as a fualt current capable of very high in-rush currents finds all paths to ground. What size is your service, or main disconect?
The last time I worked in a Coast Guard hanger, I do remember a cable with an outer diameter close to that of a 2-4 AWG, however, it may be a thicker insulation. Nevertheless, until you can find out more, that I would guess is large enough. You are only discharging static which to my knowledge has a very, very low amount of current.
I'll see what I can find out about the size of cable.
AggiePhil
19
Feb 9, 2005 07:53 PM
apache
Sep 22, 2004 10:48 AM
schorb
Aug 19, 2004 08:25 AM
tool
Feb 7, 2004 12:25 AM
White02Sport
Oct 6, 2002 07:11 PM
