Driving multiple monitors from one CPU
We need to push two overhead projectors from our display computer at church, one in front for congregation, and one in rear for choir to read.
We also have the control monitor in back to control the display program. Total of 3 monitors, 2 pushing the same signal. Can I get a VGA splitter/amplifier? Or another video card? recommendations? |
If its the same signal needing to be displayed then a splitter or another video card would both work fine...
Scratch that, multiple signals... Get a dual output video card and use a splitter off of the signal that is going to the projectors and use the other output for your monitor... The software with the card will allow you to control what is displayed from which output |
Originally Posted by bnold
(Post 1574235)
I'm trying to get them to set me up that way here at work cause I work in Team Track and Excel at the same time. Need two monitors to be able to work both. I'm told by the IT people it is just a video card and another monitor.
Originally Posted by Dieseldude4x4
(Post 1574438)
Cool, I'll go see what the hold up is. :cool:
Check to see if you have a dual-head video card. If thats true you can just hook the monitor up, may have to fiddle with a few settings but it should be up and running in no time.
If you already have a dual one, then you could hook up the monitor to one of the plugs, and then get a splitter to split the 2nd output and mirror the displays. I love having dual monitors, I can DTR in one window and do whatever else I want to in the other. |
you guys are to high tech, hahaha......really I am just jealous
us rednecks just hang a couple mirrors
another idea as opposed to using a dual monitor graphics card you can just add a second (PCI) graphics card so each monitor would have its own graphics card. Depending on wattage, you can run 2 PCI graphics cards and the one the system already comes with. I assume you are running XP.
Originally Posted by GhettoVaquero
(Post 1574810)
Pretty much all dual head video cards will have all the necessary features built into the driver to do what you want to do. The only setting is to go to your video settings and tell Windows to extend your desktop on to the 2nd monitor.
As far as the output that will be split, I would highly recommend getting a vga splitter with an amplifier built in. I tried using a regular splitter to do this once, and the screen/projector were so dim you could barely read them. The amplifiers are in the $50 range. |
Originally Posted by I PASS GAS
(Post 1575914)
Correct I was referring to the guy who suggested using multiple single head video cards would need additional software... The dual head cards ship with the needed software |
if it's the same video feed wanted on all 3 monitors, cheapest and easiest way is a video splitter. different video feeds require as stated above dual head video cards.
