Building a flatbed?
Old Feb 15, 2012 | 09:16 PM
6cylinders's Avatar
Building a flatbed?
What should the distance be from top of tire to under side
of flatbed? Unloaded.
I don't want the tires rubbing when loaded
2002 Ram 2500 4X4 reg cab long bed.
Thanks
Old Feb 16, 2012 | 12:07 AM
j_martin's Avatar
Thanks
Usually you figure on the axle hitting a suspension stop, usually a rubber pad between the axle or spring and the frame. Allow an inch clearance unless you need to chain it for winter mountain passes, then you need more, like 3 inches. (chains tend to slap a little.)
You can also design the bed so the tires come up through it almost to the top surface when loaded. Often one car tandem trailers are set up like that.
Luke S
Jul 19, 2003 11:44 PM
j
Jun 11, 2003 02:10 PM
CMN_NOT_STROKN
Mar 1, 2003 08:45 AM
Dec 12, 2002 06:44 AM
35
Nov 8, 2002 08:36 AM
