Battery Question.
Old May 19, 2009 | 06:47 PM
ramlovingvet's Avatar
DTR'S Chaplain
Battery Question.
I have no service batteries in my truck but want to add water. The only access I see is the little window that shows green when they are good It unscrews. Can you fill through it?
Old May 19, 2009 | 06:58 PM
chaikwa's Avatar
Is this a trick question?
chaikwa.
Old May 19, 2009 | 07:24 PM
DTR'S Chaplain
Umm No I had it on slow charge and cooked em down a bit and am trying to save them for a while.
Old May 19, 2009 | 07:34 PM
chaikwa's Avatar
I thought 'maintenance free' meant they were sealed, no venting. Also meaning that even if the liquid 'boiled', it would condensate back into liquid and nothing could ever be lost.
chaikwa.
Old May 19, 2009 | 07:45 PM
DTR'S Chaplain
Dont know looks low thats why the question.
Old May 19, 2009 | 07:49 PM
chaikwa's Avatar
Well here's a thought; I don't know about the green dot removal, but why not drill a hole over each cell so there's a way to fill them, then seal the holes with something like a rubber sink plug? I would have to assume there are still 6 individual cells and removing the green dot will likely only fill one of them.
chaikwa.
Old May 19, 2009 | 08:19 PM
DTR'S Chaplain
Hmmm. Not sure about that I Guess I will try to pry a cover off and see whats up.
Old May 19, 2009 | 08:31 PM
Fronty Owner's Avatar
chaikwa.
maintenance free will boil down... the sides start to bulge. If your lucky, it blows a rupture disk instead of blowing sulfuric acid and water all over the place.
If all you have is the health window, how can you tell its low?
Old May 19, 2009 | 08:35 PM
DTR'S Chaplain
It unscrews And I looked down it.
Also not holding a charge for beans.
Old May 19, 2009 | 10:17 PM
jrs_dodge_diesel's Avatar
Might want to replace them at this point. Especially if it has been a few years since they were put in.
Old May 19, 2009 | 11:46 PM
DTR'S Chaplain
Just over a year. Cant afford to get new ones right now or I would.
Old May 20, 2009 | 12:15 AM
Colo_River_Ram's Avatar
With age comes the cage
Some maintenance free batteries have the screw off/on caps(hid under a label) is this one of them?
If so were the plates covered with electrolyte?
If it looks low put some distilled water in the cells..You normally fill to the bottom of the fill hole tubes..
Old May 21, 2009 | 12:10 AM
12valve@heart's Avatar
If they are only a year old, there should be some warranty left on them (until you start prying or drilling on the battery).
Old May 21, 2009 | 07:42 AM
Hvytrkmech's Avatar
Exactly as 12 valve stated.
The green dot is an indicator for one cell only. It does not show the condition of the entire battery. Unfortunately once a battery has been subjected to extended overcharging (cooking), they are junk and can not be saved.
Tim
Rancher99
Apr 18, 2011 09:46 AM
jesussaves
Nov 7, 2010 06:55 AM
EdmontonCanada
Oct 10, 2008 11:37 AM
taildragger
38
Dec 19, 2006 09:49 AM
planejane
Aug 23, 2004 03:17 PM
