Atv question
Originally Posted by blackdiesel02
well this 660 went 72 MPH and the only reason i backed out of it was because i was fixing to throw er into a sharp turn. 63 to fast???? ur kiddin right??
Now if you want speed take my DS for a spin. Stock it will hot the rev limiter in 5th gear at 75mph. I put 2 inch taller tires on the back and it would still pull to the rev limmiter in fifth. I found a table on the net once that claimed at 7700 RPM in fifth with 22 inch tires with stock DS gearing was good for around 82mph. I then put a 1 tooth smaller sprocket on the front so my top speed should be back to around 75. Yes thats fast enough, for me anyhow.
Mine tops out at 48 mph. With the mudbug mud tires it is plenty fast. Kind of hard to keep straight.
Thanks for all the info. I think I will just go out there and worry about if I have problems.
oh did i not say it was down hill ??
and sorry to burst ur bubble but it was goin 72. i tried takin the corner that fast but then the front end started shakin real bad so i let out of it real quick.... that would have been quite the wreck
