changing rod bearings Jeep 4.0L $$$$
Old 03-11-2007, 08:42 PM
jeeptjstud's Avatar
Anybody know whats involved in changing rod bearings, does the engine need to be pulled out or can it be done by removing the oil pan?
Anybody know how much a mechanic would charge?
Old 03-11-2007, 08:50 PM
Admin Team Leader
Lary Ellis (Top)'s Avatar
I changed them in my old CJ5 6 banger by just pulling the pan. Of course I have put a number of engines together so it really wasn't a big deal. Be sure you replace the oil pump and the rear main seal while you are at it
I don't have a clue what somebody might charge for that.
Old 03-11-2007, 08:56 PM
jeeptjstud's Avatar
so can they be changed without removing the engine? Can you just pull the pan and change them out?
Old 03-11-2007, 08:59 PM
chromegrill's Avatar
I have done this several times on 4 liters and if you are in there you might as well throw some mains in it too. You can get to everything when you drop the pan. I paid less than 100 in parts at AutoZone, Advance auto and some other shops wanted almost double that so it pays to shop around. Don't know what a shop would charge to install, probably a couple hundered.
Old 03-11-2007, 09:01 PM
this a TJ? XJ? auto?
Old 03-11-2007, 09:17 PM
jeeptjstud's Avatar
It is in a 99 grand cherokee WJ, auto
Old 03-11-2007, 09:31 PM
jeeptjstud's Avatar
the motor was sludged up to the point that i had to dump motor flush into the spark plugs to get the engine to free up enough to crank. I have flushed the motor out and I believe I have taken care of the sludge problem for the most part. I thought rod bearings were shot when the oil pressure drops at idle......my oil pressure drops to 5-10psi at idle and goes to 40 when I rev it up. Maybe I am wrong at diagnosiing the problem. I pulled the valve cover off and the rockers and springs look good.
Old 03-11-2007, 09:33 PM
had 2 4.0's around that same year and both ran fine but sounded like a bad rod knock, turned out it was torque converter to flexplate bolts were backing out and hitting the tranny case. Pull the inspection cover before you buy parts...
Old 03-11-2007, 09:34 PM
you killed your oil pressure sending unit with the motor flush or it still has sludge in it...common problem, replace sending unit
Old 03-11-2007, 09:37 PM
scottsjeeprolet's Avatar
wouldn't hurt to drop the pan and have a look and maybe replace the seals, and oil pump. I did it on mine back before the 350 swap. I'm pretty sure it is a 2 piece rear main seal.
Old 03-12-2007, 09:27 AM
spunbearing's Avatar
In my experience 5-10 psi at idle and 40 psi revved is normal for some engines. Is the bottom end making noise?
Old 03-12-2007, 11:46 AM
jeeptjstud's Avatar
yes, there is some knocking going on and it sounds like its in the bottom of the motor.
Old 03-12-2007, 12:22 PM
pull that inspection cover off before you buy parts, as a former jeep tech, I've seen it before not only on some of my trucks...
Mutt68
09-25-2012 12:51 PM
bradler
23
08-07-2011 12:55 AM
Stelldo
08-29-2007 08:42 AM
dsljunkie
09-15-2003 10:43 AM
Quick Reply: changing rod bearings Jeep 4.0L $$$$
