Air Tool Equipment
Air Tool Equipment
I've got an air compressor and want to start getting some air tools but the quick couplers I originally bought aren't all compatible. What is the industry standard quick coupler type? I've seen M type, T type, A type and I am guessing that one of these is more widely used than the others. Any advice is greatly appreciated.
Waylan
Waylan
If I remember right, there are at least three different configurations. I ran into the same problem and ended up buying a bunch of them at once and replacing them all so everything matches. Not all that expensive and now I can use my tools without having to rob couplers back and forth to match things up.
If I am not mistaken, the "Industrial Interchange" is supposed to fit two of the other configurations.
Good Luck
Good Luck
Thanks for the comments guys. I just didn't want to buy one particular type and find out later that the "standard" was a different one. I didn't even realize there were different ones until I had some that wouldn't connect. I believe from my other research that the M type is probably the most common.
Anybody got a preference on hose diameter/length and a hose reel? I am thinking about a wall mounted manual reel that will hold 100' of 3/8" hose. Do impact wrenches and such need a larger hose than this to operate correctly? Are the automatic rewind reels the best thing since sliced bread? I don't like to do things twice........too much money and time involved........I'd like to get it right the first time.
Waylan
Waylan
I had the wall mounted manual reel, it was OK, but next time I will get the auto rewind model. Mine holds 50', which is enough to go anywhere in the garage. I have my air compressor right by the door, so I can also go about 45' out into the driveway as well. Has worked well for over 3 years now.
a lot of times I like the auto reels that hang in the center of a garage, especially if it is a two car wide unit, hose in the middle of the ceiling is reachable from the center and easy to get at. A good unit is the best thing since sliced bread, a cheap one will serve you better sitting on the shelf at the store than in your garage...... Trust me, I have a cheap rewind unit imn my truck tool box for use of my on board air and impact tools & that cheap winder drives me nuts.
Mkinner
Sep 21, 2010 07:57 PM
