Adding a beavertail(dovetail) to a gooseneck
So I found a killer deal on a 20ft gooseneck(1500$) and the thing looks like new. The issue, it does not have a beavertail on the back. My question is I'm a decent welder, is this something I could just add, any suggestion on the way to go about it, basically I want the advantage you have with being able to have less ramp angle.
also suggestions on the best place to buy a gooseneck hitch for a 98.5 |
You could add it on, but it'd be easier to cut the frame and drop it to an angle if there's enough room after the rear spring hangars.
chaikwa. |
Originally Posted by chaikwa
(Post 2655816)
chaikwa. |
I agree with chaikwa. I would rather do that if possible over any kind of extension.
If its an I-Beam I would sugest wehat Chaikwa has. Box frame wouldn't be to bad to add an extension on but they are generally used on RV's
not tryiung to be a [nonono] but since you had to ask if it was possible I hope you aren't planning a "do it yourself" project, find a couple of "good" welding machine shops, tell them what you want and get bids comparing the "how" to the cost; have them include a materials description so that you can compare the type and sizes of the steel being used
not done correctly you'll turn your $1,500 bargain into the value of scrap metal good luck and you should end up with what you want for $2,250 to $2,500 which includes the $1,500 cost of the trailer |
Originally Posted by Purplezr2
(Post 2655807)
also suggestions on the best place to buy a gooseneck hitch for a 98.5 As far as the hitch, I'd suggest a B&W turnover ball. On my truck it's rated for 30k gross, 7.5k on the pin.:cool: |
Chaikwa has potentually the easy way to do it. Trailers are built with axels in a spicific relation to the hitch for tung weight. if you add to the rear, depending on what its built out of you could be throwing your weight off.
Originally Posted by ArkansasRam
(Post 2660865)
http://www.texas4x4.org/gallery/albu...1629.sized.jpg |
If you go to a few places that sell trailers a lot of the 14000 do not have the frame notched and "bent" down. the dove is added on. We have added to several but ALL had to have the axles moved. Axle position on most trailers is 60/40. 60% of the total length in front and 40 behind the center point of the 2 axles. I would be all over a well built 20ft gn for 1500 bucks dove tail or not.
Originally Posted by smoking
(Post 2661063)
chaikwa. |
If you were closer to Missouri I would take a look at it and try to help you! I teach welding and project construction. If you get me a couple of photos of the trailer and its back end I can make some suggestions to you. If it is an I-beam frame I know of some real slick tricks to add on to it. Let me know if I can help.
(Post 2655816)
chaikwa. |
If anyone actually ends up doing this, I have a graph I can email that shows the wedge that can be cut out and how many inches of wedge will make how many degrees of tail angle depending on the height of the beam.
Oh, and just so the southern boys don't confuse you too much, it IS called a beaver tail! <I'd click the laughing smily if the smilies were working!> chaikwa. |
I would add pictures to this thread if I knew how, as for the math involved that should not be an issue(I have a math minor). I still have not decided what I want to do, that reason for want a beaver tail is for easier loading of cars, tractors, or stuff.
