42 Ford Pickup
Old Mar 25, 2010 | 11:14 AM
kyncl's Avatar
42 Ford Pickup
I'm helping a friend put a 1989 Ford Lincoln motor in a 42 ford truck. The lincoln had digital gauges in the car. Can we put analog gauges in the truck and have them work. Or what do we need to make analog guages. We are using the sending units that were on the lincoln and putting after market gauges. Thanks
Old Mar 25, 2010 | 11:22 AM
12valve@heart's Avatar
I would doubt that the factory Lincoln sending units would work with aftermarket gauges but I can't say for certain. Why not just use the aftermarket sending units that are designed to work with your aftermarket gauges?
Old Mar 25, 2010 | 11:23 AM
Fordzilla's Avatar
The senders for aftermarket analog gauges are entirely different......Ben
Old Mar 25, 2010 | 11:37 AM
kyncl's Avatar
Thanks for the quick replies. We wanted to use the factory plugs on the motor. We found a place that will make a wire harness for the ford cab. So, what you are saying is to replace the factory sending units. Do you think they will be able to use the factor wire harness on the motor?
Pele
Cummins Conversions
May 21, 2014 06:49 AM
Mexstan
Dec 16, 2007 11:16 PM
RJ285
Aug 17, 2007 11:32 PM
DeanM
Jan 9, 2007 08:17 PM
Rich Shahoian
22
Oct 28, 2002 01:40 PM
