Sponsored by: CARiD
View Poll Results: What oil filter do you use?
Amsoil EaO80 or Donaldson ELF7349
16
15.09%
Fleetguard LF16035 (Stratapore)
42
39.62%
Fleetguard LF3972 (OEM)
13.21%
Fram
1.89%
Baldwin BT7349
15
14.15%
Wix 57620 (NAPA 7620)
10.38%
Wix 57620XE (NAPA 7620XE)
2.83%
Purolator PureOne
1.89%
Purolator
2.83%
Donaldson P558615
0
0%
Mobil 1
0.94%
I have a bypass too!
1.89%
Multiple Choice Poll. Voters: 106. You may not vote on this poll
Old Mar 4, 2011 | 10:21 AM
AH64ID's Avatar
What oil filter do you use? Do you have a bypass?
If you use more than one kind, list your preffered filter.
Trying to see what's the most common.
If you use a Stratpore LF3894 just select the LF16035. If you use a Hastings LF608 just select Baldwin BT7349.
Here is the data I have on the filters listed.
Donaldson P558615 40 @ 98.7%, 20 @ 50% Cellulose
Fleetguard LF3972 30 @ 95% (35 @ 98.7% last info) Cellulose
Wix 57620 30 @ 95%, 20 @ 50% Cellulose
Wix 57620XE 25 @ 95%, 14 @ 50% Glass Enhanced Cellulose
Baldwin BT7349 30 @ 98.7%, 12 @ 50% Synthetic blend
Fleetguard LF16035 30 @ 100% (25 @ 98.7% last info) Stratapore Synthetic
Purolator L45335 20 @ 97.5% Cellulose
Purolator PL45335 20 @ 99.9% Synthetic
Amsoil EaO80 20 @ 100%, 15@ 98.7%, 7 @ 59.97% Nanofiber Synthetic
Donaldson Elf7349 20 @ 100%, 15@ 98.7%, 7 @ 59.97% Nanofiber Synthetic
Mobil 1 M1403 10 @ 50% Synthetic blend
Old Mar 4, 2011 | 11:12 AM
madhat's Avatar
Administrator/Jarhead
I just use the OEM. Get them at the dealer most of the time.
Old Mar 4, 2011 | 12:00 PM
signature600's Avatar
Stratapore LF16035
Chris
Old Mar 4, 2011 | 12:23 PM
Scotty's Avatar
Top's Younger Twin
Baldwin on everything that I can get them for.
Picking up Baldwin filters for my wife's JEEP today.
Old Mar 4, 2011 | 12:51 PM
CTD NUT's Avatar
Fleetguard LF3894 Stratapore
Is the Amsoil EaO80 and Donaldson Elf7349 the same filter? They are outstanding compared to the others you have listed.
Old Mar 4, 2011 | 01:02 PM
AH64ID's Avatar
Yes they are the same filter with different paint.
Old Mar 4, 2011 | 01:27 PM
DBLR's Avatar
Switched to Amsoil oil filter as I get a lot of extra removed form the oil for the extra $5.00 it cost over the Fleetguard Stratapore. When it comes to fuel filters I only use Baldwin PF7977. As for the Mopar oil filter don't like the idea of using a 30-35 micron (last I heard) nominal rated oil filter but then it is better then a Fram but not by much IMHO.
Old Mar 4, 2011 | 01:33 PM
cincydiesel's Avatar
Originally Posted by signature600
Stratapore LF16035
Chris
Same here..
Old Mar 4, 2011 | 01:55 PM
TxDiesel007's Avatar
baldwin BT7349
has been good to me as an oil filter so far.
Old Mar 4, 2011 | 04:27 PM
I guess I should have said I use the LF3894 Stratapore on my 12v...technically, it's a 72516556 AGCO part, but it's made by Fleetguard
Chris
Old Mar 4, 2011 | 05:32 PM
MikeyB's Avatar
Fleetguard Stratapore or Baldwin.
MikeyB
Old Mar 4, 2011 | 05:57 PM
ripping r's Avatar
i just use the napa gold 7620. i did not know about the 7620XE. i will use that from now on.
Old Mar 4, 2011 | 05:58 PM
Tedonlin150's Avatar
What do the numbers mean?
Old Mar 4, 2011 | 06:14 PM
AH64ID's Avatar
The numbers tell you how efficient a filter is. Like the OEM filter is rated to remove 95% of all particles 30 um and larger in the oil. Where the Amsoil is rated to remove 100% of all particles 20um and larger, and 98.7% of all particles larger than 15um. The more, finer particles you remove the less contaminate wear the motor gets.
Old Mar 5, 2011 | 09:04 AM
rufushusky's Avatar
Baldwin...5.60 a pop...but I have found Donaldson ELF for like 12.90 a whack online so I might try them next time. I do an Amsoil bypass too.
